SnowPlow test #1
   / SnowPlow test #1 #1
SkunkWerX
Platinum Member
Central Maryland
Kioti CK2510H
We got a few inches of snow today, not a big deal, but, it was an opportunity to give the snowplow it's first true winter test.
After adding the 3" carbon steel cutting edge, I then added a rubber squeegie, sandwiched between the steel edge and the moldboard.
BEFORE
The rubber squeegie strip is worth it's weight in gold. A true improvement. :D
It even allowed me to scrape our cobblestone/paver front sidewalk, which I would never do with just a steel blade, for fear I'd snag pavers and rip them up. :eek:
AFTER
It did snow some more, adding a couple more inches, so the plow got another quick test right before dinner. it's still snowing a little, due to stop by 8pm, so maybe I'll do a quick run after it stops, just another excuse! ;)
If you have pavement, the rubber squeegie strip is something to consider.
   / SnowPlow test #1 #2
How much was it? That is something I would consider. Any idea how long it last before it wears away?
   / SnowPlow test #1 #3
Wow, that looks great!
I've got to start working on making me one of those.
   / SnowPlow test #1
The rubber strip was like $19, plus shipping. It was made for a full size truck plow.
I was able to cut it into 4 pieces. So I have spares.
I have no clue how long it lasts.
Here is the guy I got it from: (Not a sales pitch, I don't know him)
Rubber Plow squeegie
   / SnowPlow test #1 #5
That's what I need to turn my 4-in-1 plow blade into a snow machine, a bolt on squeegie strip to replace the metal blade. Anybody know where I can find one?
jmf
   / SnowPlow test #1
jmf
My suggestion is get a rubber strip an inch or so wider than your metal edge, then use your metal edge over top of it as a retainer strip, let the rubber hang down a little farther than the metal edge.
It is conveyor belt material.
They even sell belt material at TSC. I got mine on flea-bay, see link above.
   / SnowPlow test #1 #7
What link is that?
About how far below the metal edge? Is there any proven materials for this kind of use?
jmf
   / SnowPlow test #1 #8
It looks like you have a heated driveway and probably turned the electric on! Looks like it did a Super Job..
   / SnowPlow test #1
jmfox said:
What link is that?
jmf
LINK: Rubber Plow Squeegie
My rubber strip is 4" wide, my steel edge is 3" wide, I drilled both of them on the C/L , so the rubber is sticking down about a 1/2" on mine.
   / SnowPlow test #1
JohnK, I think the ground still has a little heat in it, it was a sunny day yesterday too.
Of course, if the snow is driven on, and it freezes to the ground, the rubber isn't going to cut it. Even steel edges will slide over top of it once it's been smashed into the pavement and freezes.
2024 CATERPILLAR 255 SKID STEER (A51242)
2024 CATERPILLAR...
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2010 NEW HOLLAND B95 BACKHOE (A50854)
2010 NEW HOLLAND...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2020 Kinze 3505 High Speed 6/11 Planter (A51039)
2020 Kinze 3505...
