snowplow on my NH TN65
   / snowplow on my NH TN65 #1
tractorman71
central NY
built out of stuff I had around the shop, parts from fisher,western snowplows,hyd. cylinder from an old IH corn planter. and some spare time.
   / snowplow on my NH TN65 #4
Your pictures need to less than 100k.
Make them about 92k to make sure.
lets see if this resizer bidness works
another pic
   / snowplow on my NH TN65 #8
Nice setup. I've seen lots of plows that attach to the loader arms via QA but never one that used an electric hydraulic pump to lift the blade. Is it a lot of work to mount/dismount from the tractor?
On a second look maybe that's not an electric cylinder at all.
electric my butt!!! it is plumbed into the loader valve. up/down left/right are done with the loader joystick
the blade is a fisher, it comes off with 2 spring loaded pins and 2 hyd. couplers. I made the plow frame compact enough so I can put the loader on without removing the plowframe. blade comes off in 15 seconds, plow frame comes off in 5 mins.
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
