Snowblowing rules of thumb
   / Snowblowing rules of thumb #122
Snow blowing rule #1: Without a cab, snow blowing follows the same rules as pissing into the wind. Rule #2: Rear blowers simulate strychnine poisoning and make you eligible for PTSD compensation.
LOL, like rule # 1!
Should be a #3
Don't bite off more than U can swallow==clogged chute!
   / Snowblowing rules of thumb #123
Unless you live in the woods in the snow belt and in February you run out of room to plow snow. Then you need the mule to move it! Snow pusher much better than a plow but I知 finding out a blower tops them all! Thanks
   / Snowblowing rules of thumb #124
Don’t forget to oil the chain on front blowers every 4 hours with chainsaw bar oil. PS a pin hole in the foil seal on your gallon of oil works great!
   / Snowblowing rules of thumb #125
The rear blower doesn't bother me. I sit sideways in the seat so I'm not straining my neck looking directly behind me
That's what I'm doing too. Mind you, I only used it twice so far to blow my 1000' private road. I just received a tractor steering wheel spinner knob that I'll install before the next snow fall (8-10" forecast) tomorrow. With practice, it might make steering easier knowing exactly where the wheels are pointing.
   / Snowblowing rules of thumb #126
Rule #472, put rubber scrapers on your impeller.
   / Snowblowing rules of thumb #127
This has probably already been posted, but before any snow, make sure there are no objects in your path that can cause damage to your snow blower!!!
I was clearing my neighbor's drive last winter...hit one area I didn't normally clear and the blower (73" Frontier rear blower) partially ingested a frozen door mat.
Stopped the blower cold...
Forunately, just one (of two) shear bolts snapped, but removing a frozen doormat wrapped around the auger was a SOB
   / Snowblowing rules of thumb #128
Oh my..... I can only imagine how frustrating that would be!!
   / Snowblowing rules of thumb #129
   / Snowblowing rules of thumb #130
We had such a lame snow this past year, I didn't even get our blower out.... And just pushed it with our 6x6 and blade
Hatchback (A59231)
Hatchback (A59231)
INOP/NON-RUNNING 2000 Ford F-550 Truck, VIN # 1FDAF57F0YED79120 (A57453)
INOP/NON-RUNNING...
Volvo A40D Off Road Dump Truck (A56438)
Volvo A40D Off...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
Compressor (A55973)
Compressor (A55973)
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
