Snowblower Impeller Kit
/ Snowblower Impeller Kit #2
My neighbors 47 throws snow 30' at least-not sure how much more is needed...
/ Snowblower Impeller Kit #3
Same here , I 'm blowing snow 6-7' in height and back 20-30' . Not sure what you are trying to gain ?????
/ Snowblower Impeller Kit #4
I had a 1/2" gap between the impeller and housing on my 59". I put strip of 1/4" thick high density plastic inside the housing as a liner. Riveted it in place. It made a world of difference. Almost tripled the distance of throw and prevented plugging in wet and light snow.
I believe the paddle kit will work for you. If you added a plastic liner too . . . I can imagine using less RPM and power to do the same work.
/ Snowblower Impeller Kit #5
Orangejbird, Where did you get the plastic? I would like to give that a try. Thanks
/ Snowblower Impeller Kit #6
I cut it from leftover manger liner a local farmer had. Not sure where you'd find it in your area. Got an Ag. plastic dealer?
/ Snowblower Impeller Kit #7
was wondering if this might help the 47in work a little better. all comments suggested:)
I put that kit on a 42" Haban single stage thrower on a L&G tractor. It made a huge improvement... especially with wet snow.
My new rig has a JD 44" two stage with a plastic impeller. The shape of the impeller blades don't lend it to adding the kit... I wish it did.
If your JD 47" has a metal impeller you'll like the kit.
Clarence is a nice guy and ships promptly.
/ Snowblower Impeller Kit #9
Anyone in your neighborhood work on dirt track race cars? Some of them use the plastic in different thicknesses.
Landpride PL3048 (A64126)
Landpride PL3048...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2017 Hyundai Trailer (A62613)
2017 Hyundai...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
2000 International 4900 Tandem Truck (A66285)
2000 International...
