Snowblower Impeller Kit
/ Snowblower Impeller Kit #2
My neighbors 47 throws snow 30' at least-not sure how much more is needed...
/ Snowblower Impeller Kit #3
Same here , I 'm blowing snow 6-7' in height and back 20-30' . Not sure what you are trying to gain ?????
/ Snowblower Impeller Kit #4
I had a 1/2" gap between the impeller and housing on my 59". I put strip of 1/4" thick high density plastic inside the housing as a liner. Riveted it in place. It made a world of difference. Almost tripled the distance of throw and prevented plugging in wet and light snow.
I believe the paddle kit will work for you. If you added a plastic liner too . . . I can imagine using less RPM and power to do the same work.
/ Snowblower Impeller Kit #5
Orangejbird, Where did you get the plastic? I would like to give that a try. Thanks
/ Snowblower Impeller Kit #6
I cut it from leftover manger liner a local farmer had. Not sure where you'd find it in your area. Got an Ag. plastic dealer?
/ Snowblower Impeller Kit #7
was wondering if this might help the 47in work a little better. all comments suggested:)
I put that kit on a 42" Haban single stage thrower on a L&G tractor. It made a huge improvement... especially with wet snow.
My new rig has a JD 44" two stage with a plastic impeller. The shape of the impeller blades don't lend it to adding the kit... I wish it did.
If your JD 47" has a metal impeller you'll like the kit.
Clarence is a nice guy and ships promptly.
/ Snowblower Impeller Kit #9
Anyone in your neighborhood work on dirt track race cars? Some of them use the plastic in different thicknesses.
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
Altec DC1317 Chipper (A63689)
Altec DC1317...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
