Snowblower Impeller Kit
/ Snowblower Impeller Kit #2
My neighbors 47 throws snow 30' at least-not sure how much more is needed...
/ Snowblower Impeller Kit #3
Same here , I 'm blowing snow 6-7' in height and back 20-30' . Not sure what you are trying to gain ?????
/ Snowblower Impeller Kit #4
I had a 1/2" gap between the impeller and housing on my 59". I put strip of 1/4" thick high density plastic inside the housing as a liner. Riveted it in place. It made a world of difference. Almost tripled the distance of throw and prevented plugging in wet and light snow.
I believe the paddle kit will work for you. If you added a plastic liner too . . . I can imagine using less RPM and power to do the same work.
/ Snowblower Impeller Kit #5
Orangejbird, Where did you get the plastic? I would like to give that a try. Thanks
/ Snowblower Impeller Kit #6
I cut it from leftover manger liner a local farmer had. Not sure where you'd find it in your area. Got an Ag. plastic dealer?
/ Snowblower Impeller Kit #7
was wondering if this might help the 47in work a little better. all comments suggested:)
I put that kit on a 42" Haban single stage thrower on a L&G tractor. It made a huge improvement... especially with wet snow.
My new rig has a JD 44" two stage with a plastic impeller. The shape of the impeller blades don't lend it to adding the kit... I wish it did.
If your JD 47" has a metal impeller you'll like the kit.
Clarence is a nice guy and ships promptly.
/ Snowblower Impeller Kit #9
Anyone in your neighborhood work on dirt track race cars? Some of them use the plastic in different thicknesses.
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
2008 New Holland T2420 (A60462)
2008 New Holland...
2022 EZ-GO ELITE...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2001 International 4000 DT 466E (A60462)
2001 International...
