was wondering if this might help the 47in work a little better. all comments suggested
Snowblower Impeller Kit
I had a 1/2" gap between the impeller and housing on my 59". I put strip of 1/4" thick high density plastic inside the housing as a liner. Riveted it in place. It made a world of difference. Almost tripled the distance of throw and prevented plugging in wet and light snow.
I believe the paddle kit will work for you. If you added a plastic liner too . . . I can imagine using less RPM and power to do the same work.
I cut it from leftover manger liner a local farmer had. Not sure where you'd find it in your area. Got an Ag. plastic dealer?
