Snowblower chute hyd. conversion
/ Snowblower chute hyd. conversion #1
Couple of Achers
3rd rock from the sun
L4740
Just finished up converting my snowblower chute from manual to hyd. A 4" stroke cyl. did not have enough movement, and a 6" stroke had to much. But I did not want to limit the movement so I decide on the 6". After some discussion on the Hydraulic section on how to either limit the stroke of a cyl. or how to shorten the cyl. rod. I decide it would be best for me to just lengthen the lever assembly on the chute to accommodate the 6" stroke. I was able to use the existing pivot hoe in the lever and drilled one more to hold the bracket. I also made the bracket it two pieces. This accomplished two things. 1) I did not need to lengthen the lever as far, and B) I only used one bolt to hold the two pieces together to work as a slip clutch, if you will, should the chute ever becomes frozen up and when I try to adjust it, it should slip rather then bending up something. The only problem I had is if I moved the chute too abruptly it would slip a little bit without being frozen. So I drilled a 1/ 8" hole and put a aluminum pop rivet in to act as a shear pin. So far, so good. I am curious to see how it will preform this winter.
/ Snowblower chute hyd. conversion #2
Looks Great! If that pop rivet gives you a problem, just get a cheap grade 2 1/4" bolt to put in there.
/ Snowblower chute hyd. conversion #3
Nice. You are gonna love the hydraulic chute control this winter. :)
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
1989 Corvette Convertible (A61574)
1989 Corvette...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
2018 Chevrolet Silverado1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
