SNOW
LBrown59 said:
Chains on the front might be ok but not on tractors with 4 wheel drive.
What's the point then? I guess you know more about this than all the municipalites that have been doing this way since day one.... I won't speak on this any more... I do know if I say sunny and skies will probably be blue, You, Mr LBrown will bring it to argument in short order, and insist the skies will be black.
Larry,
I have hopped over from the JD forum because I have an interest in this topic. I live in western NC and although we do not get NY sized snows often, we do get quite a lot at times (and it get darn cold, too). My area has a unique problem, that being of snow with icy underlay and steep grades, many of which can be greater than 20%. My understanding specifically related to compact tractors, is that the spur gears in many of these lighter weight, higher horsepower machines might not be up to the potential torque peaks that could occur when plowing with front chains. Interestingly though, many of us do this daily when we use our loaders or move gravel, etc. Also, our local dealer has said he recommends against them mainly because people with limited experience do not install them correctly, making a potential for the chain to come loose and damage the tractor or operator. This would not be a issue so much for machines with heavier front differentials and for folks with more plowing experience, such as commercial or municipal plowers. That said, JD for example offers a front tire chain for its compact tractor. This probably says as much as anything about what the company thinks about front chains on its compact machines. One would think (and hope) that if they felt it unsafe or not beneficial, the chain would not be offered. I do not have any now, but have a set on order for our big snow months of Jan and Feb, so that I will not slide off the hill. For me, I would replace a spur gear rather than lose control on a steep unguarded roadside, so my vote is "pro" front chain.
John M
jmseven, I think you summed it up; if JD offers chains for it's CUTs then they MUST be compatable. Why would a respected manufacturer sell/install an item that would damage it's machine and thus incur warranty claims against itself?? I do understand that the tractor's dynamics would be changed and due care should be exercised, but if you cannot take the time to learn how to properly operate your machine you have no business operating it IMO. I can understand some dealers being reluctant to offer them to less experienced operators. Just like chain saw dealers pushing safety chain due to liability concerns even though they limit a chainsaws cutting performance.
This all stated, I will contact my dealer to get his take and order a set if appropriate. Besides, that's why I used a respected dealer to begin with.
/ SNOW
I had good luck getting the chains from tirechain.com. The Rockwell scale is 360 on the steel in the chains.
I also purchased these tirechains
which are nice.
The chains I got from JD for a Gator are low grade steel FYI and cost more.
Where the **** is the snow? I live south of Buffalo and although we tend to get more than the famed Buffalo, we are getting robbed this year. The Holiday Valley ski resort is not even running yet and it is the middle of December. BAD BAD BAD for business.
Rumor has it that Lake Erie's temperature has gone up so the first Noreaster is going to blast us. Watch the news for cool stories about Buffalo later this winter...I bet we make headlines again and I bet I will be glad for the chains and weighted tires on the Kioti.
Over the weekend I got in touch with a big seller of car and tractor chains, they are located in Pa and advertise a lot on the I-Net. Here is basically what he had to say on the subject of CHAINS ON THE FRONT TIRES OF 4 WD TRACTORS:
In 20 yrs of selling chains I have never heard of anyone having problems running chains on 4 wd tractors. He also told me my best source of info would probably be a tractor dealer and I'm sure he did that to cover his back.
I think I am going to wait until I see what the 45 does in the snow without and then make a choice, am also going to check with my neighbor who plows commercially in the winter with diesels and 4wd's.
Like Larry I am not going to write anymore on the subject.
I like the Bird Dog, I had Pointer at 1 time
LBrown59 said:
All Rite then since it's ok to run chains on the front it would also be ok to miss match the front and rear tires correct?:confused:
For you, yeah it is.
I like to mismatch left and right tires--
I did this years ago on my 1969 Ford Galaxie; radials on the left, studded snow tires on the right...
It makes banking the sharp curves in West Virginia more interesting. ;)
:D :D :D
I generally remove all the wheels and prop the tractor up on bricks. It isnt very useful like that, but atleast it prevents wear and possible damage to the drivetrain ;)
:D You one smart man Mith!:D :D
The snows usually go away on there own come spring time!:D
Even better is to live where the snows do not come.:D
LBrown59 said:
I have 4 different brands of tires on My 20 year old Dodge D50 P U.
All 4 are p195Radials
You know, I believe you.
LBrown59 said:
I have 4 P195x75x14 all season Radials on my 20 year old Dodge D-50 Pick Up.
They are 4 different brands and 4 different tread patterns.
Ran my 1983 D-50 for 12 years with a different tread design on each wheel.
Our First Car - My First Car - My Tractor
http://www.tractorbynet.com/forums/1031201-post17.html
Okay, okay, I said I believe you already. Let's not push it. ;)
Egon, send me a tenner and I'll tell you all the secrets to avoiding wear, depreciation, and damage to your tractor :D
LB, and now you deleted both. Gee, 4000 posts and you still cant do it right!
Well that sounds like a pretty fair deal Mith if you send one cent and double the amount every day for a month and I'll tell you how to buy a new tractor!:D
Mith said:
LB, and now you deleted both...
Fortunately for the quoting feature, I now know what the deleted posts said.
I laughed so hard, people came into my office at work to see what was going on! :D
But have you ever put snow tires on the front wheels of a front wheel drive car? :confused:
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
Tennant M30 (A64127)
John Deere 1025R (A62177)
John Deere 1025R...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
