Snow Equipment Owning/Operating Snow sticking to blade.
   / Snow sticking to blade. #12
Actually your best value if you are going to be using WD-40 is to go to Wally World or Harbor Freight and buy it in gallons and then pour it in a spray bottle for application purposes. It's a lot cheaper that way.
   / Snow sticking to blade. #13
I bought one (Northern Tool) for my 7' rear blade. What a difference! I've used it three years now and still works great. Plowing is faster and easier too. The snow seems to roll off the moldboard (as opposed to being pushed sideways).
   / Snow sticking to blade. #15
penokee, I'm not sure what is the best substance to keep snow from sticking to your blade but PLEASE, to Theowegian and all others that have suggested using WD-40, DON'T. From an environmental point of view, you might as well go and pour another volatile organic compound like BTEX (gasoline) in your drinking water, because that's exactly where it will end up. I've spent over 25 years in the environmental business and I've seen petroleum distillates, such as TCE and BTEX, ruin entire water supplies. It's been estimated that one teaspoon of oil can contaminate over 400,000 gallons of water and make it unfit for human consumption. When you spray WD-40 on something and water washes it off, it doesn't just disappear, it ends up in surface and ground water where it can persist for a long, long time.
   / Snow sticking to blade. #16
That's exactly what I was thinking. All that WD 40 can't be good for the environment.
Although more expensive, I think that using Pam cooking spray would be a safer alternative, especially for the kids and pets that like to play on the snow piles.
I also think that a good quality automotive wax should work well - it takes some elbow grease to apply and buff it out, but it should last for a month at a time, and how much work is it to apply to a blade, compared to how much work it takes to do an entire car or truck.
I also wonder if Rain-X makes a product that would work, now that they have stuff for glass and plastics.
   / Snow sticking to blade. #17
will second THIS. besides , what if some snow sticks to the blade or the fel or the blower? if u forget to scape it off it will melt on the floor, but usually it is cold enough for it to still be there the next time i pull out.
   / Snow sticking to blade. #18
When I was in the motocross racing business, we would spray a heavy coat of PAM, or some other type of organic cooking spray on underside of fenders, frame, hubs, rims, etc., to keep the mud, and the extra weight associated with it off the bikes.
Should work for snow. Try it.
Good ideas all. The snow picture is from last year. Have had a little on the ground, but it melted. We had 2 years with 300 inches, so get plenty of opportunity to play with the snow.
"Tamarack needles never fall on the snow" and since the Tamarack still have a few needles, it'll be a while before the permanent snow comes.
The potential environmental pollution from Wd-40 is a good point. Will evaluate that approach before using it. The comments triggered another thought - plan to contact local city and County DPW crews who have large snowplows, etc, will see what they use, if anything. Will post what I find out.
penokee /forums/images/graemlins/smile.gif
   / Snow sticking to blade. #20
I wondered about using spray-on bedliner, has anybody tried that?
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2007 GALYEAN 130BBL VAC TRAILER (A58214)
2007 GALYEAN...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2019 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP3KFA58619, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2019 Ford F-150...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
1974 Ford F600 Grain Truck (A56435)
1974 Ford F600...
