snow removal
/ snow removal #1
Hombre
Goldendale, Wa
Branson 4020R
So who's doing snow removal now with their tractors and what implements are you using. We're getting a hard snow today (late for here) and it's "supposed" to get up to 30" for the week. We'll see. I'm ready. Front plow and rear snowblower for the edges when the road starts to "narrow".....
/ snow removal #2
Been a pretty mild winter so far here. Usually February is our snowiest month. I'm ready to plow with a 7 1/2' plow on front and a double auger blower on back. Supposed to be mid 50's here this weekend but eventually the snow will come.
/ snow removal #3
View attachment 636406 . So far 5" and it's snowing hard. I will consider plowing in the morning if we have, at least, 8" and it's still snowing.
/ snow removal #4
All I use is a snowblower. Our road goes up the side of a ridge so I run out of room fast if I plow. I also found that the plow just creates a nice hard berm when we have a melt between snows.
/ snow removal #6
What kind of surface will you be removing snow from, Hombre?
/ snow removal #7
4F7A4B64-E463-48B2-94D6-E177640DC441.jpegHave about 9-10 so far... still coming down. I blew snow earlier this evening so as not to be overwhelmed tomorrow. Have loaded mounted blower with 3 point hydraulic tank and rear pto pump.
/ snow removal #8
Been nice mild winter here so far so no need for tractor just pickup with plow,but if old man winter decides to come visit front plow and rear scraper blade on the tractor.
/ snow removal #9
Winter has been passing us by so far this season. I'm still using FEL with bucket and 3pt box blade. Told myself I'd have my 3pt blower by now, but for some reason I just haven't been motivated. Using what I have works, but it is by no means time efficient at all. If I was doing this commercially (which I don't), I'd be going hungry (well, that and no snow this year).
I think eventually I'll end up with a 3 pt blower and a FEL mounted angled blade (w/ 3rd function). Kind of holding off until after we buy another place and relocate. Want to see what the new layout ends up being as far as driveway and parking areas, to know what I have to work with. I also keep going back and forth on wanting either a 72" or 84" blower. I'd like the 84, but am a bit concerned if it ends up being too much for my 32 pto hp. Our snow is almost always dry due to the cold air temps, but we do get heavy (as in deep) snows, and lots of drifted snow due to our windy conditions. I'm right at 70-72" across at my back tires, so would like a little extra blower width with the 84. Plus the 84 sticking out farther will make it easier to get closer along side of things like parked vehicles and out buildings.
So I've been going back and forth between either the 72 or 84 Woodmaxx with hydraulic chute rotation and hyd angle deflector (cabbed tractor, with 2 remotes already). How has your 84" Woodmaxx been working for you on your 40 hp machine Hombre? Your snow is probably wetter than ours.
/ snow removal #10
Front blade and a 74" pull blower on the back. First winter with this setup. Three events with about 4" each to far but 6-11" in this weekends forecast. We get 120-140" a year. Just under an acre of open area to clear and 250 yards of driveway. All level.
Very important to read opinions and experiences of others who get about the same amount and type of snow you encounter as well as the type of terrain they deal with. If I got less than 60" a year, I would not have invested in a blower. When I used a plow truck, 6' banks were normal.
/ snow removal
All gravel. About a mile of main drive plus around my house and shop. I no longer have to plow out to the barn and clean up that area since I got rid of the horses. I also do several neighbors drives that are along the lower road about 1/2 mile below my house. I've made "changes" to the hydraulic plow I read that others have done to theirs to help with plowing gravel drives to help keep from removing "to much" gravel from the road. I've watched some videos of guys plowing their paved drive and it really makes me envious of that pavement. Cost prohibitive for me.
/ snow removal #13
Hombre, it sounds like you make do.
/ snow removal #14
Plowed TWICE in the last 24 hrs up here in Deer Park, WA (north of ya Oosik). I had about 8-10” to clear and due to the dense snow, decided to do a few passes with the walk behind snow blower and chuck a bulk of it off to the side. Did a neighbor’s home too (husband passed away & was a member of the CIA Flying Tigers) and she had 3 times the area to plow.
My tractor is armed only with the standard bucket and a 7’ back blade. Did most of the plowing backwards. I’ve decided that I’ll add hydraulics to angle it on the fly to make plowing more efficient. Thought about adding wings to the bucket... anyone try that?
/ snow removal #15
Plowing [ or blowing snow on ] gravel is always a pain until you get the top surface to freeze up. You will then still run into soft spots near mailboxes and the edge of the road. If the roadway is froze, you will still dig in if you get over onto areas that have been covered with snow that you are widening out. On your 94" front blade, you could add a steel pipe over your cutting edge that will help a lot. But it will still dig in if the ground gets soft. Our local machining/steel outfits make and stock them in quantity. But you can make one out of 2" I.D. schedule 80 [ 1/4" wall ] steel pipe. You cut a slot in the pipe with a plasma cutter that will allow you to slide the pipe onto the blade. Then add a couple tabs welded onto the pipe, then bolted onto the blade to keep it in place. Does not take much to keep it on. You can go bigger pipe, but 2" seems to be the norm up here. I used to use ABS pipe, and tried bigger sizes. At some point it will just ride up on top too much. I have them on both of my blowers and my little front blade. Not perfect, but works better.
/ snow removal #16
Moved snow for 8 hours yesterday. Had between 18-20” on the ground depending on area. Did my place and 6 neighbors places. Used front mount blower
/ snow removal
In answer to Slowpoke Slim's question on the 84" snowblower, the 40 horse Branson has no problem with it. It weighs a bit over 900lbs so it helps me when it gets a bit slick out. I have R4's on the tractor and they are just about, no, they are, worthless in snow. I usually have to run chains on all fours when it gets more than a couple inches deep or there is any ice or hard pack. I've done a lot of snow removal here using the front bucket (only when necessary) and 7ft back blade on my old 32hp tractor. When the berms along the drive would get up to a ft or two high and hard, it would just throw the back of the tractor over. Then the bucket went to work to open the road wide enough for a car to pass as the drive is not very wide to begin with. I'm sure you fella's that do this regularly know exactly what I'm talking about. I've lived here 20 years and every year is a learning experience in snow removal. I had a TD 9 cat I used for a few years, now that thing could move snow but also really tear stuff up if things got remotely out of kilter. Had a 87 International 6yd dump that was an X city plow truck, had sanders, double action box (would lift from the front or from the rear to feed the sanders) and a 12ft plow. It would also really move snow but I had to use chains and 3 or 4 yds of sand to get around. Trying to do small areas around the house, neighbors drives and such was pretty dicey. So here I am now with a new(er) tractor, big snow blower for when the berms get big and the road gets small, and the 94" front blade for the majority (I hope) snow work. I think it will work pretty good once I get a handle on how to use it. I've noticed that when changing angles on the blade you have to "adjust" the roll back on the plow to keep it level so one side doesn't dig in. That was an interesting discovery. Also in answer to Jerry, I have done a two inch steel pipe tack welded to the cutting edge and a 12" piece of stall mat that rolls under the pipe. Read about that from someone. Seems to work pretty well so far, and I'm sure I'll tear up less road with this setup than I would with just the blade edge. The best by far was the dump truck and plow but man, I had that in some tight spots around the neighborhood that I wasn't sure I would ever get out of. I probably should add that the "driveway" was originally built with a D8 dozer run up through the woods and a bunch of rip rap dropped for a road base. Over the years and a lot of gravel and it is what it is. Up hill all the way to my house, not level in any direction with humps and bumps with a few small "donikers" sticking up when the gravel starts getting moved out thrown in. When I first moved here I would not haul my horses down it inside the trailer, I would tie them off and let them walk. It was a bona fide 5MPH road in my 4x4 cause' it was so rough. You could actually (if you were so inclined) drive it at 20 today without to much drama, I still only go about 10 though. Sorry for the book size reply guys.
/ snow removal #18
Heading out to plow again. 6 inches of new snow. And powers been out for 30 minutes. Got to love the generator.
/ snow removal #19
We still got nuthin' for snow. A tiny bit of powder last night just sprinkled over the top of all our sheet ice.
/ snow removal #20
No snow to speak of yet this year but January is our snow month. Most of the time I can take care of the snow with the ATV and a snow plow. However the land around us is very flat and the wind can whip the 2" of snow into three foot drifts. For moving snow like that I use a loader and a tractor with chains.
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
Knapheide Service Bed (A61165)
Knapheide Service...
King Kutter II Tiller for sale.
King Kutter II...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A61568)
2000 Thomas Built...
2021 Tesla 3 Sedan (A61569)
2021 Tesla 3 Sedan...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
