Snow Equipment Owning/Operating Snow Removal
/ Snow Removal
Here is a couple more of my complete setup. We got 3" more today so I was just playing. Sorry for the poor quality, took the pics with the cell.
The combo of the front 7' Snow Plow and the 7' Woods Rear Grader Blade work great.
Chris
Thanx Chris,
Just curious are you a pilot?
/ Snow Removal #22
Ya what he said. I lived in Upper Michigan during the blizzard to 78' and dont recall seeing banks like that. I'm going sway and say Alaska.
Wedge
/ Snow Removal #23
Upstate N,Y where the record for the most snow that has fallen in a 24 hr period for the United States.
/ Snow Removal
Thanx for all your replies!!!!!!
/ Snow Removal #25
This is the only equipment I can use when the driveway gets snowed in & the Kubota can't handle it.
Photoshop. Computer geek.
Not even Lake Tahoe has 100' snowbanks.
Looks some believe it....sorry to burst your bubble.:D
/ Snow Removal #26
In the UP they're smart enough to drive on top of it not dig down to the bottom.
Wedge
/ Snow Removal #27
I rigged this old POS to my 3710......... It came on a '48 Willies plow frame. I have used it since 2000 and it is still doing the job.
Ain't pretty though.........
/ Snow Removal #28
With the usually small amount of snow in CT I'm another vote for using the loader. Depending on your amount of snow removal larger area, long driveway it might be worth the setup of a plow. Your profile pic show just about the ideal bucket position for snow removal (back edge down, front lip slightly up). I really like the ABS pipe over the front edge idea... that gives you a slick guide to roll the bucket down against to get a consistent bucket angle. I've been thinking that for a little additional scraping action, I could bolt a thick piece of rubber mat (think horse stall mat) to the front of the ABS pipe. What do others think about this idea?
/ Snow Removal
/ Snow Removal #31
Living in lower NH I probably get a little more snow then in Ct., but my driveway is 300 feet long and gravel. When I use my tractor during some of the smaller early season storms or when it is one of those snow/freezing rain/rain kind of stormsand the top of the ground gets a little soft I will backdrag the drive with my bucket. Otherwise I use the float with the bucket curled up just a little so I am not digging in.
/ Snow Removal #32
That puts you in montague, up in the tug hill and land of lake effect snow............
/ Snow Removal #33
I run a front mount snowblower on my lawn tractor & it does fine with a 24" snow fall and pavement. My windrow is very deep and packed and I have been using my loader & box blade. My plan is to make a snow pusher out of a 6' plow blade. My neighbors have dirt lots & drives that I take care of. 1 drive is the access road into 1 of my fields. A snow pusher has shoes on the bottom of the box that slide over the ground and keep the blade from digging in. I want my loader on my tractor all the time & a snow pusher you just drive up to it & throw a chain over the hooks and off you go.
/ Snow Removal #34
I have lived in a number of states and by far the most snow/the most often was when I lived in upstate NY, Endicott area. 2-3' dumps are expected. I did what I could with my garden tractor but my neighbor with a big JD and rear blower saved my bacon many times.
Here in SE MN I am on the edge of needing a blower. Most years I can get by with the FEL on the MX5000 but its slow going and and real pain. I think I will get a blower and be done with it.
/ Snow Removal #35
Snow removal is dependent on so many factors.
Does the ground freeze up solid underneath, how quickly, and for how long?
Snow-powder, wet, soon to melt, destined to stay around for months.
Lot-room to move, no room to move, a place to shove snow, long drives, ditches or banks.
Types of typical snows-rare but heavy, frequent, perpetual
Figuring out the typical or average needs YOU have and matching up with the varied options is key. There are no universal applications.
FELs,
FELs with blades,
back blades,
front blades,
front blowers,
3pt blowers
All have their place in the arsenal. If you get it moved, when it needs to be moved without tearing up stuff, you're doing OK. If the wife gets stuck or can't get out, you not doing so well.
2015 Chevrolet Cruize Sedan (A59231)
2015 Chevrolet...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
