Snow Removal On a Chip & Tar Driveway
   / Snow Removal On a Chip & Tar Driveway #1
Snakebit12
Raphine VA
Kubota G1800 Kubota BX2360 Kubota M7040
I recently installed a chip & tar finish on a previously graveled 2,000' driveway - it was not cheap. I live on top of a hill and got tired of the steepest section of the driveway washing out under heavy rainfall. It simply was not possible to grade the driveway without having it look like a banked race car track.
To get the water off the new driveway, I had asphalt water bars (look alot like speed bumps) strategically angled across the driveway on some of the steeper sections. With Florence and Michael, these water bars were tested...and passed.
So, I am satisfied with the performance under heavy rainfall. Now, the questions shifts to "How on earth do I get snow off this 2,000' driveway without tearing up the finish?"
I have several Kubota tractors...an M7040, a BX2360 and an old G1800. The former two are 4WD. I also have a 24" self-propelled walk-behind Troy-Built snowblower.
I also have a 7" Blue Diamond hydraulic dozer blade that I have used with the M7040 to plow snow when I was dealing with gravel. This blade is designed for a skid steer and does not work very well on the LA1153 FEL. The weight of both the FEL (1,500 lbs) and the blade (1,000 lbs) fell on two metal mushroom skid shoes - I could not float the blade as it simply buried the skids and dug up the gravel. I eventually learned to hold the blade a few inches off the ground but would inevitably gouge the driveway somewhere along the line.
There is ZERO chance that I will use the blade on the FEL on this new driveway in its current configuration.
I have considered:
1. Using the M7040, bolt on a polyurethane blade to the Blue Diamond blade along with polyurethane skid shoes. I fear that the weight issue will still result in destroying the driveway.
2. Again using the M7040, install a quick-hitch on the 3-point and, in conjunction with the polyurethane blade and skids, plow backwards. I have rear hydraulics so I could control the angle from the cab. This would be more akin to a skid steer arrangement as only the weight of the blade would rest on the skids. I hate the idea of plowing 2,000' backwards.
3. With the BX2360, purchase a front blower ($$$$) and attach polyurethane skids on the blower to prevent it from marring the driveway surface.
4. Again with the BX2360, purchase a rear blower (less $$$$) and attach polyurethane skids. But I am still going backwards.
5. Use the Troy-Built. I would need 3 passes to clear the driveway...that is over a mile of walk-behind snow blowing. Yikes.
6. Simply staying home until the snow melts. Here in Virginia, the snow doesn't stick around for too terribly long.
I appreciate the fact that I will need to mark the edges of the water bars to avoid hitting them using whichever method is most effective.
The amount of know-how on this board is amazing so I am hopeful that someone can point me in the proper direction.
John (aka Snakebit12)
   / Snow Removal On a Chip & Tar Driveway #2
3pth snowblower with the feet lifted a bit.. That's what I use now and is the best implement for removing snow I have found.. It's quick, clean, doesn't wreck any surfaces and leaves no banks..
   / Snow Removal On a Chip & Tar Driveway #3
How about having a set of gauge wheels welded onto your rear blade? Set the gauge wheels so the blade rests slightly above the road surface, 3pt floating, forward driving snow removal. Quick and no damage to your road.
The thing with Virginia winters is you frequently get light snows which aren’t deep enough to use snowblowers.
Everything attachments sells a set of gauge wheels for their landscape rakes that you might be able to modify to fit your blade.
   / Snow Removal On a Chip & Tar Driveway #4
We have had the Town do some chip seal roads, the blades do a number on them and your water bars would really get roughed up.
If you use a rear mounted blade turned backwards at a steep angle and just drive forward it will move snow sideways it will take several passes but may not move a lot of stone off your driveway.
How loose is the stone on the surface? Packed good in the wheel tracks and loose in the rest?
Do you have to move the snow off the full width of the driveway or can you let it pile up on one side so that any stone can be brought back in the spring?
   / Snow Removal On a Chip & Tar Driveway #5
With a properly cured tar and chip driveway/road the only loose stones would be the ones the tar didn't stick to.
As for your dilemma, I would go with the gauge wheels on the BB turned backwards )>. The curve pointing towards the direction of travel.
   / Snow Removal On a Chip & Tar Driveway #6
Yes - use your rear blade and reverse it. Its what I use if I have to remove snow from my mile long gravel driveway before it freezes up, rock hard. On your M7040 reverse the rear blade and drive forward.
Also - you might want to check on one of those big rotating brush thingeys that are hydraulically driven and mount on the FEL. I have no idea how much snow they could remove from your driveway.
   / Snow Removal On a Chip & Tar Driveway #7
Can you replace the snow shoes on the blade with wheels allowing it to roll on the driveway?
Good morning - thank you for your comments.
Most center around the dozer blade - it is a sunk cost after all - thought that I would attach a picture:
Note that this is not a reversible blade - it cannot be pulled, only can push.
The gauge wheel idea is intriguing...perhaps a pair of brush hog tail wheels? Would need to weld on new yoke brackets higher up the blade as the existing skid shoe brackets are too close to the ground. Would be nice if the wheel assy swiveled....easier on the driveway, I would think.
   / Snow Removal On a Chip & Tar Driveway #9
Something like this, except on a rear blade instead. Everything attachments wants $339 for a set of bush hog wheels. Pricey but they look stout and have good floatation.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56435)
2017 Rogator...
2022 Kubota Z422-54 Zero Turn Mower (A56435)
2022 Kubota...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
Caterpillar Midi Excavator (A56857)
Caterpillar Midi...
