Snow Plow video
/ Snow Plow video #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Does anyone recall that thread which had a video of the little IH or Cadet tractor clearing the roads in a campground in NW Pennsylvania?
I cannot recall the TBNer who posted or the name of the thread. IIRC, it was first posted in th Rural Living forum late last year, then this forum a few months back.
If this helps, most of us were amazed how well that 2WD tractor (an oldie, but a goodie) did.
/ Snow Plow video #2
I remember it. It was a video from the drivers seat. It is an impressive video.
/ Snow Plow video #4
Took the chains off of that tractor this weekend and pushed some sand that washed up into the creek crossing. Also pulled a couple trailer loads of firewood since the Gator is having some starter trouble and the Mule was pulling the log splitter.
I also picked up this little JD 425 with 54" 4-way blade and 54" mower... Check out the video of getting it here:
YouTube - John Deere 425 - Winter Arrival
/ Snow Plow video
/ Snow Plow video #10
Roy, come move all my snow next year, and ill film you doing it. ill give you the videos.
Seems fair to me. watta ya say :thumbsup: :laughing: :laughing: :p
/ Snow Plow video
That's a plan!!!
If I start out in August, I should be there by October!
/ Snow Plow video #13
Is it just me, or did that Cub Cadet with the front mounted blade push through that snow a lot easier than anything I ever attempt ? There's something special about the conditions in that video. Very fluffy snow ?
Excellent traction on the ground underneath, with no underlying ice ?
Snow that was actually only 5 inches deep ? A John Deere 4320 pushing him from behind ??
/ Snow Plow video
Several of us made that same comment when the video was originally linked to a post. Must be those great chains he had...plus a dry snow.
Heck, I was amazed he knew where to plow since the road wasn't marked.
/ Snow Plow video #15
There was as much snow as seen on that railing in the first shot - about 10". It was relatively light snow, the first major snowfall of the season and the first time the drive had been plowed. The surface was dirt/gravel. The rear tires each have 150lb weights and double ring chains. Note that the tractor is the same as a Farmall Cub, only it sits about 9" lower, hence the "Lo-Boy" designation.
/ Snow Plow video #17
OK, I'll admit you simply have a very good combination of equipment. I used to have chains on my tires ( 12.4 x 28) when I had rather worn out tires. Now that I put new tires on the tractor, the chains fall down between the tire lugs, and are not as effective, so I don't use chains any more. Another problem was very poor traction on ice or hard packed snow. I helped that problem by driving sheet metal screws into the top of the lugs. I used a screw that had a sharp edged top, and of course was not so long that it penetrated the tire completely. I put about 40 screws into each tire, and left them in all year. They made a big difference in traction on ice. After about 5 years now, many of the screws have disappeared, but I may reinstall some before next winter. I suppose there are tire chain sets that don't fall down between the lugs, but I'm not sure I want to use chains again. I think they tend to tear up my dirt and gravel driveway . Now that I bought a walk behind snowblower to help with my snow moving, I have to be careful about raising rocks to the surface. Compromises, always compromises !
/ Snow Plow video
OK, I'll admit you simply have a very good combination of equipment. I used to have chains on my tires ( 12.4 x 28) when I had rather worn out tires. Now that I put new tires on the tractor, the chains fall down between the tire lugs, and are not as effective, so I don't use chains any more. !
Brother, we're just discussing the cool videos...how you rig for snow is the fodder for another thread.
/ Snow Plow video #19
Ahh don't worry your car or something else will pick them up sooner or later :D
/ Snow Plow video #20
Maybe you're discussing a video, but I'm discussing how I rig for snow, as did the man who made the video. Suddenly, that hat you wear makes a lot of sense.
2018 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 PETERBILT 579...
2012 International (A59230)
2012 International...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
7ft Metal Texaco Pump (A65583)
7ft Metal Texaco...
2011 PETERBILT 367 (A65643)
2011 PETERBILT 367...
