Snow Plow started
   / Snow Plow started #1
camshawn
Langley BC
Mihindra 3616
Winter is almost here so it is time to get moving on this project. The blade is 8' x 24" x 1/4 rolled at a 24" radius. The ribs are 1/4 plate cut to match the radius on the plasma table at work and 1/4 x 2" flat bar for the cross pieces. The cutting edge is 3/8 x 3" mild steel that is reversible. It should last for 5 to 10 years.
It will be frame mounted to our Mahindra 3616. I will use the loader joystick to raise and angle the blade as needed with a crossover relief on the angle.
Pictures:
Lay out of ribs, tacking.
   / Snow Plow started #2
that looks great! good job!
   / Snow Plow started #3
1/4" skin, you're not fooling around are ya!:thumbsup: Are you setting it up to "trip".
   / Snow Plow started #4
Well, that is surely a road few travel. Most tractor snow plows that I see are retired from pickup duty.
   / Snow Plow started #5
Looks good so far.
Looking forward to see how you do the a-frame and sector. Hope you are planning on a pair of SA cylinders for that crossover to work properly.
How much plowing do you do? I am betting that mild steel wont last as long as you think. Thats a pretty heavy plow on a small 3/8" edge
   / Snow Plow started
Thanks for the comments.
The blade will trip, held back by some springs. The little tractor (15hp) with a 6 1/2' blade slowly bent over the last 20 years. This one is a little heavier and has more ribs. The shoes should keep the edge mostly off the ground to help with the edge wear as long as they are not worn out.
I have 2 sa cylinders for the angle. I have the A frame in my head, I just have to get it out.
Our drive is about 400 yards of gravel. We do not get a lot of snow some years (3" last year)but others can have 3 feet, sometimes powder, sometimes poop.
Cam
   / Snow Plow started #7
Very nice, maybe a bit overkill on the cutting edge bolts.
   / Snow Plow started #8
Thats what I call doing it right the first time..nice work.
   / Snow Plow started #9
I frame mounted an 8' fisher on my Kioti ck35. I use the rear remotes to operate the angle cylinders. To raise the plow, I was going to mount a new cylinder to my loader lift hydraulics, and remove my entire loader. I got lazy and for this year I just remove the ssqa loader bucket and sling to the plow from the existing loader framework. It works good. Very simple to go from loader to snowplow. I know I cut a corners with the plow lift this way but I like it like this.
   / Snow Plow started
Not much progress this week, fixing things and cleaning up the yard before winter. I went today to get some angle at metal mart, closed on Saturday. Did get another spool of wire and some new contact tips at the toy store so it was not a wasted trip.
On my little tractor, I used the bucket to lift the framemounted plow for years, worked fine, the chain let the plow float and I could push down with the bucket as needed. I will unmount the loader and use the loader valve to control the plow. Our loader comes off in about 10 minutes and that should be faster as I practice more.
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
