Snow Equipment Owning/Operating Snow plow sizing
/ Snow plow sizing #1
archeryantny
Hillsborough NJ
Kubota L48
What is the maximum size snow plow I would be able to use on a Kubota L48 or comparable size tractor? I will be plowing fairly level driveways with some slight grades mixed in as well.
/ Snow plow sizing #2
How wide is the tractor?
Frame mounted plow or FEL mounted plow?
"Average" type of snow? (dry, wet)
/ Snow plow sizing
74" wheel base
Fel mounted
The average snow fall pretty much runs the gamut. Plowable snow could be from 3" wet to 3' feet powdery snow during a Noreaster. In all honesty its kind of hard to put a finger on, but normally i'd say +/- 6 inches, 5 or 6 times a year.
/ Snow plow sizing #4
I think chains or no chains would be a huge deciding factor. Tractor size and horsepower are useless if you can get the power to the ground.
/ Snow plow sizing #5
Wide enough that the tractor wheels are on plowed ground when the blade is angled.
/ Snow plow sizing #6
If you mount the blade on the front frame, then I'd say easily an 8' would work for your tractor.
I've a 7' blade on a Deere 4300 32 hp, and have enough oomph to handle more (but don't need any more, especially if my wing plow is going to work as planned :) )
/ Snow plow sizing #7
I run a 6.5' Meyer on my Jinma 284 with no chains and it does fine. Its 28 HP. It handled 18" snow in the picture no problem but I have since loaded the rear tires.
Chris
/ Snow plow sizing #8
There might be a legal limit if you are plowing on public roads - UNLESS you are plowing for the Town, State, etc and/or in a declared emergency.
Worth checking ?
/ Snow plow sizing #9
I know I have a 8ft on the front of my L48 and I wish I could find a used 9 or 10 ft it would handle either one with out any problem
Linx EQ07020RS 20ft Trailer (A65640)
Linx EQ07020RS...
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
John Deere MX8 3-Pt 8' Rotary Mower (A66285)
John Deere MX8...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2013 Caterpillar 420F 4x4 Extendahoe Loader Backhoe (A64194)
2013 Caterpillar...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
