Snow plow project
   / Snow plow project #21
awesome build.
do you have any photos of how you mounted the plow frame (black parts) to the tractor mount that you fabricated (gray parts)?
i personally agree completely with using the loader valve. lift, float and down-pressure for scraping ice and hard-pack.
ATV plows vary greatly in build and quality. i use a 5' Warn that is plenty strong for my BX.
   / Snow plow project #22
linky no worky. At least for me - says invalid attachment specified.
   / Snow plow project #24
3 years later the plow is still working well however the 13 inches of snow yesterday was too much for this setup. I needed a blower for this one. at least this was a dry powder type of snow. Plowed for 5 hours to get our road open so i can get to work tomorrow. View attachment 353656View attachment 353657
Nice work on your project.. in regards to the lift cylinder and hitting something, yes float works but the whole plow has trip springs so unless it's locked, you should be good.. looked like you made it ~3~ years without a problem. I did a similar project back when I got my BX24.. I converted over the plow set up from my JD, and the nice thing about it is that it's quick attach/detatch. I have pics and a write up on it here but that's years ago now.
Nice to see someone else go through all the bother to do this, still not sure if it was worth all the time and effort, but that's how most of my projects are!
You might consider a 3pt hitch blower and keep your plow on.. this way you can use BOTH @ the same time (sort of) and it would be ab excellent ballast!
   / Snow plow project
Thanks, it took a beating on the 13 inch snow but I gave it an inspection and all looks good. I am watching for a 3 point blower deal.
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52128)
2020 Massey...
2023 LANDHONOR VPC-11-72W VIBRATORY PLATE COMPACTO (A51244)
2023 LANDHONOR...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2023 John Deere 8R410 MFWD Tractor (A52128)
2023 John Deere...
