Snow Attachments Snow Fighter
/ Snow Fighter #1
botaman2
ct.
Kubota L3010
Yesterday's storm gave me the opportunity,to use my new LR/grader-blade combo. MY 7' landscape rake used to be a seasonal implement,but now it will be used year round.The flip down grader blade worked great for cleaning up behind the front blade. I also plow my neighbors drive that is all stone,the grader blade with wheels did no scalping. will post a few pictures.
/ Snow Fighter
Another picture
/ Snow Fighter
picture #3
/ Snow Fighter #5
<font color="blue"></font><font color="blue" class="small">( picture #3 )</font> </font>
Are those gage wheels? If so, 2 or 3. Look like a relatively simple setup and a lot better than tearing up surface.
Tom
/ Snow Fighter
yes!they are gauge wheels,they work great!
/ Snow Fighter #7
botaman,
I was refering to "Pic 3" and the front blade. But, that rake, blade, and gage wheel setup on the rear looks like it would be hard to beat!
Tom
/ Snow Fighter #8
Nice setup Botaman...
I have the 6ft version of that Landpride rake... I like it a lot.
I'm just finishing up building a front mount snowplow like yours.
Can you show me a pic of how you mounted the lift
cylinder to the loader frame??
Was it a solid tab with a hole for the cylinder pin??
a pic of the front of the machine up close would help
me out a lot...
Thanks,
Chris
/ Snow Fighter
No! the Meyers snow plow has the standard skid shoes.
/ Snow Fighter #10
Thanks. Wasn't sure from the pic (eyes aren't what they used to be). Sure do like that rake setup though!
/ Snow Fighter
I have an old post from earlier this year that has a bunch of pictures on the Meyers plow mods. Do search in the customization forum,words to search for are snowplow L3010,date newer than one year.
/ Snow Fighter #12
I really like your Meyers snowplow modification. I am going to build one myself using yours for inspiration. Mine will have to be different however, as I have an l4330 and things are set up different (ie - no loader brace to attach to underneath or in the front). I have a couple of questions I was hoping you could answer for me. 1. How much space did you leave between the front axle and your two square horizontal frame members - and how did you figure out how much you needed so that the axle would not hit it on uneven ground? 2. How far apart are they?
/ Snow Fighter
The distance between the top of 2"sq. tube and the bottom of the axle is 1 1/4". That distance is when all is level. The minimum distance when the front axle is at full travel is 1/2". To get my clearance spec. ,I jacked up the front axle. I then pivoted it thru it's full swing and took measurements. You also asked for the distance between the 2"tube,It is 6"to the inside edge. Hope this info. will help. /forums/images/graemlins/smile.gif
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
NEW Wolverine 66" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 66"...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2006 Utility Spread Axle Trailer (A62679)
2006 Utility...
