Snow Snow clearing newbie - Recommended steps
   / Snow clearing newbie - Recommended steps #21
Here is some more snowblowing advice from a front mount blower user, if applicable to a pull behind type;
First, never disengage the pto unless, or until, the chute is clear of all snow. Disengaging the pto with a chute full of snow (especially wet heavy snow) is a great way to instantly end up with a plugged chute when you re-engage the pto.
Second, when the job is finished, be sure to run the blower until all snow is cleared from all moving parts. Then move / rotate the chute full range stop to stop to be sure there is not snow that can freeze and block its movement before the next startup.
Second, contrary to what others have said about running the engine speed for the rated pto rpm, With a gravel driveway, Once you get the hang of your equipment's operation (i.e. how slow you can run the engine (pto) without plugging the chute in various snow conditions), you may find your driveway and yard restoration work next spring to be easier if you slow the pto speed and try to not throw and spread the snow (including gravel) quite so far and wide. I have a front blower with an adjustable deflector on the chute, but I also vary engine speed in order to minimize the areas that I need to clean up each spring. Throw it as far as you need to, get the snow out of the way so you don't get snow banks that cause extra drifting, but remember that you may be the one who has to clean up any extra mess in the spring.
Third, When spring comes and it is time to move the gravel back into the driveway. After the box blade, a power rubber paddle broom
does a great job to really clean things up. Works best (easiest) to get it done before the grass starts growing in the spring.
I used to clean up the gravel from my yard, now I just leave it and mash it down when I roll the yeard in the spring. Unless it is excessive, it doesn't hurt a thing. But I didn't know there was a tool to do this, may have to look into this.
   / Snow clearing newbie - Recommended steps #22
I have a Stihl Power Paddle. Mostly needed for plowed stones, not blower. The blower SENDS 'EM! Works great.
Not me:
With a gravel driveway I would pack the snow in the first few storms. You dont want to blow half your driveway through your snowblower. If you cant do this then I would say get a plow.
Thanks, good advice. We had a guy plowing last year... he moved a lot of gravel off the drive, part of the reason I'm doing it myself now. At least I know who to blame).
First thing you'll learn is that it's VITAL that the discharge chute is pointed downwind. You'll have to adjust that as your direction and conditions change. If you get caught in the "snow-cloud" from the discharge blowing back at you, you become an instant snowman!
As mentioned above, tilt the leading edge up so it doesn't dig into your gravel. Let it ride back on the shoes a little.
I run mowers, tillers, and snowblowers at WOT. No reason not to. Your blower doesn't have to rotate at EXACTLY 540 rpm and, in this case, faster is better.
I've never had my tractor-mounted snowblower jam up with snow or ice.
Look at your PTO angle when yours is raised all the way up. If it's extreme, don't raise it that high while it's running. Every setup is a little different. As said above, you can just pick it up so it's not dragging sideways on the turns without raising it all the way. I don't disengage mine when I turn around.
Don't point the discharge at anything like a car or person -- not even as a joke. You won't believe how much gravel and junk will get picked up (regardless of how careful you are) and you can easily break glass, etc.
Otherwise, just have fun with your new snow machine!
I think the PTO angle sb OK, but will check. The whole unit does not come very high off the ground when in full raised position (like maybe 10-12"). Will double check when I get out for the 1st run. I was thinking about that chute position and flinging gravel... I will need to focus on that until I have some hours of this under my belt.
It is fun! Well.. any tractor work is.
   / Snow clearing newbie - Recommended steps #25
^^^^This^^^^
Also, I spray the blower and chute areas with a coat of Fluid Film at the beginning of the season. Amazing! Without, the 'treated' snow near the public road will plug me instantly.... not after Fluid Film though.
The front mount SB does about 20% duty. The 3pt blade does 80%.... all of those 2-3" 'nuisance' snows is faster with the blade.
Yeah I'd wait using blower until you have a solid snow/ice surface. Otherwise its just gonna be an inaccurate gravel shotgun. Many that uses the bucket gets them shoes you put on to prevent it from digging into the gravel (Can't remember the name). Else inverted blowers are great instruments, here is a video of me with 18inches of snow last year.
GReat video!
   / Snow clearing newbie - Recommended steps #27
Ok I'll do this. Yes, there is a 540 PTO range on the tach,but I'll start it up on the low end and see how it goes.
I've always been told it's also good practice to throttle down before disengaging PTO on modern equipment without overrun clutch, as it will save wear on the PTO braking mechanism, although I'll admit I often fail to actually follow this advice. Always start PTO at low idle, if possible.
I wear ear protection anyway on the tractors. My eyesight is a little iffy, don’t want to be deaf too :).
Same but opposite, here! Too many years of hot rods, shooting sports, machinery, drumming, bagpiping...
My family bought me a tee shirt that says "I DESTROY SILENCE." :ROFLMAO:
   / Snow clearing newbie - Recommended steps #28
Now that you have the good equipment, you know it won't snow much this year, right?
   / Snow clearing newbie - Recommended steps #30
Unless the driveway area is very obvious, drive some marker stakes for guidance. Our main paved driveway isn't an issue, but a gravel driveway that curves to the sheds. Although I frequently use that driveway I tend to plow the adjacent yard unless I stake it out.
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A58017)
2002 WESTERN STAR...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2019 Freightliner M2 106 AWD Altec AM55 55ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
HAY SPEAR, 3PT (A58374)
HAY SPEAR, 3PT...
