Snow chains for plowing with a rear blade
   / Snow chains for plowing with a rear blade #31
The older style conventional chains have more of an issue with that then the patterned Euro one's do.
To the best of my knowledge no chain manufacture recommends reducing tire pressure to install tire chains and most have cautions against inflating tires to tighten the chains.
Interesting, wonder why?
In my case, I run my rears around 5 and the "increase" is to about 10 so....
   / Snow chains for plowing with a rear blade #32
Those are excellent suggestions, thanks. Pretty much have them on the last links available outside (first pic) and inside (second pic). Have also tried increasing tire pressure after mounting and it does help somewhat.
Although these chains were recommended for my tire size, I had to adjust by removing one cross link and shortening the sides a little, but this was as small as I could go.
They aren't crazy loose without the bungees, but I am pretty paranoid about having them hit the three-point arms or fenders.
I ran my chains with rubber snubbers for several seasons and for the same reasons - I didn't want to take a chance on them hitting anything.
After my rubber snubbers started to age, I decided to try to make the chains reliable iby removing and added links so that just closing the over-center levers would make them fit snugly.
It took awhile, but I'm slow, patient, and enjoy working metal. I still safety wire the over-center lever. Goodby bugees. It is much easier to put the chains on now. As a side bonus, they fit good enough to use anywhere there is poor traction year round.
Looking at your photos, you could strart by removing one or more links from all the cross chains using a vise and leverage to open and close the cross-chain double hooks, and a grinder or hacksaw to remove cross chain links. Keep the cross chains flat. Twisted links like those make that easy. Make changes slowly....
There are places online that sell tire chain parts; wish I'd known that at the time.
Luck,
rScotty
   / Snow chains for plowing with a rear blade #33
... I believe that TRYGG is one of the manufactures that doesn't recommend tensioners and I think actually wants a bit of looseness in the chains.
OFA is the same: they do NOT recommend using chain tensioners. It appears Aqualine does recommend them.
   / Snow chains for plowing with a rear blade #34
For those that haven't seen it, Mr. Lou started a thread back in 2018 with an easy, low effort method for mounting chains.
It works well for me!
   / Snow chains for plowing with a rear blade #35
Good to hear.
   / Snow chains for plowing with a rear blade #36
Here is how I install chains, works quick and easy for me. With tractor in garage and front wheels chocked:
1. Use floor jack under drawbar to jack up back of tractor.
2. Release parking brake.
3. Lay chains on floor next to tire with the outer side DOWN and very carefully work out all the kinks.
4. Slide chain under tire with BACK end of chain lined up with back of tire.
5. Lift BACK end of chain up and hook it on most convenient lugs of tire.
6. Hold end of chain against the tire and rotate wheel so BACK end of chain goes over center of top of wheel and lock parking brake (or just hold onto the wheel so it can't rotate backwards).
7. Slide under tractor and fasten chains
8. Apply safety wires and bungees as necessary/desired.
9. Repeat for other side.
   / Snow chains for plowing with a rear blade #37
And it’s the method recommended by the manufacturer of my chains.
Thanks for the suggestions/help guys.
I agree with the poster who said I should get the front chains as well. $1,200 more is nothing compared to the damage that would ensue if I lost control going down that 25 deg slope. Someone suggested a way to make my own chains, which I greatly appreciate, but I don't have the time to deal with that right now.
The rear chains arrived today which was pretty quick! Seems everything else I've ordered for my tractor is taking months to get here. I've been waiting for over a month for my land plane and it still hasn't arrived. It would be great to get the road in better shape before winter arrives.
   / Snow chains for plowing with a rear blade #39
You may be glad you don't have your landplane yet!
I find it's better leaving the driveway as is in the fall and not running the landplane. The gravel is generally stable and locked in from traffic.
Working the driveway before winter will typically loosen up gravel creating a great looking drive, but you run a high risk of plowing that beautiful loose gravel into the ditches later as you plow snow.
Also, for the first couple of annual plowing sessions before the ground freezes, many try to raise the plow an inch (or so) above the surface to prevent scraping gravel and pushing it off the drive as they plow. Once the ground is frozen solid, the gravel seems to lock into place and you can plow a little closer to the gravel surface for the rest of the winter.
Mid to late Spring seems to be a great time for using the landplane to rework the drive while there is some winter moisture still left in the ground.
The landplane works the gravel to the top and you can rebuild the crown and clean up your edges from winter plowing. At the same time, you can recapture loose gravel pushed into the edges or ditches with a rock rake.
Pics of the drive when we bought the land, and after some 'road work'.
   / Snow chains for plowing with a rear blade #40
Tire chain mending tools eliminate the fuss and muss of fixing and adjusting side chains and cross chains.
A bolt cutter can be used safely and efficiently to shorten cross chains and side chains.
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A55973)
2019 International...
2008 CMTL 19ft Homemade Travel Trailer (A55973)
2008 CMTL 19ft...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
IRON FORCE IMPACT SET (A58374)
IRON FORCE IMPACT...
