Snow Attachments snow blowers
/ snow blowers #1
gray
Upper Peninsula of Michigan, on the shore of Super
Kubota L48 tlb
Hello, I am a new member looking for information on snow blowers. I have been through much of the forum but have not found much on the pull type snow blowers. Pronovost offers an option on some of theirs that changes them form push to pull and back. Can anyone out there give me more information on this or like types? I am running a Kubota L48 and think a 72" might be a good fit? Thanks. BTW- if I ask foolish questions as a rookie to the tractor world, I expect some laughs.
/ snow blowers #2
Can't say I've ever seen a pull type. I have a 3pt snowblower, and it works very well. Is there a reason for a pull type instead of a 3pt?
/ snow blowers
Big Bob,
It would be a more comfortable way to go in my estimation. I also have a freind who is getting a his first tractor and he does not care to be twisted around if he can help it- getting older as we all are. I don't know if I would go that route but I am interested. If they work well and can be used either way then if may be worth it. We get 250+ inches a year in the UP of Michigan and this year may be my last using the 3]4 ton truck and a plow. No place left to put the white stuff. Bent up my plow last week trying. A snow blower may be what both hs and I need. BTW- what brand, size and HP do you use. How fast can you travel in 8 to 10 inch snow-a normal day here.
/ snow blowers #5
gray,
I just got a P620 Pronovost and it's working great.
I'm using 21 pto hp to run it and 'been in some really wet snow, about 10", with no problem.
I'm not sure how fast you could go; never tried it . I just keep a nice, steady pace.
I did see on the Pronovost web site, they offer an "inverse" blower but I've never seen one "in the flesh".
It would be nice to look forward but you'd always be packing down tracks in the snow.
Are you on asphalt or gravel ?
I think the Pronovost is a great machine.
GrayBeard
/ snow blowers #6
I have a 64" 3pt Pronovost Puma snowblower. Works like a champ although the most snow I have tried it on was 15".
I am over 55 and have no problem looking backwards. In fact I do not have to look backwards, I just slide sideways in the seat and turn my head slightly to the right. I usually do one long pass, then re-position myself and go forward back to starting point and then do another pass. Looking sort of backward is not as bad as people are making it out to be.
/ snow blowers
GrayBeard,
I have visited the Pronovost site and seen the inverse option but no real info on how it works or what it does for the pusher capacity of the unit. Nice to here they must be well designed to work so well. I have read a few posts about Woods that question part of there design. Everyone likes to feel good about a purchase and I am no different. You have taken on 15 inches of snow at times? That is important. I guess my speed of travel guestion is due to impacience.
You must have a good amount of snow where you live. We have 30+ on the ground and growing. Often heavy drifts.
Thanks for the ifno. GrayBeard.
/ snow blowers
GrayBeard,
What kind of dollars are we talking about for your unit? I may have to go to a push only type if the inverse option changes the capacity when pushing the machine. Lots to think about.
I know this winter has made a statement to me about truck plowing. When the snow is banked up over 7 ft and no place left to put it, the truck takes a hit. It is fast but leaves much to be done and often scares up the lawn.
I need to get more year round use out of my investment. I also believe The matting issue will be far less.
/ snow blowers #9
Gray,
I paid 800.00 for a 4yr old machine in pristine cond. ( lucked out for once)
I'm not sure what they cost new. A guess for the P620 would be 2000.00 .
Tha Puma is a little less $, I think.
I imagine you're going to find the "inverse" models are pretty expensive.
GrayBeard
/ snow blowers #10
I paid $2000 for a 64" Puma with hydraulic chute rotator. Price was $1795 with manual crank chute.
/ snow blowers
Hello GrayBeard and MadReferee.
Sounds like I will be paying 2 bills or a bit more. There are so few dealers around here I would not find a good used anything. A new Pronovost is the most likely. I will have to find a dealer or two and start from there. My bext bet is in northern Wisconsin or Minnisota. I still am curious about the inverse option. They wouldn't make it if it didn't work?
/ snow blowers #12
Check out that linked message up above for the inverse blowers - very good info there from someone who uses one.
Would not be very useful to me on my windswept prairie - I have to deal with 3-4' snow banks sometimes, & kinda hard too - can't possibly drive through that stuff. If I were in the situation of lighter snowfalls, little drifting - then I might consider the inverse, as the person who has one does.
Running a regular 3pt is not that difficult, I'm always surprised at the problems people have with it?
--->Paul
/ snow blowers
Rambler,
I too have lots of snow to deal with but not always does it drift up. On occation it will drift 4 or more ft. Lots of lake effect snow here. I just hoped the Pronovost would be unlimited in push mode yet be good for small amounts of snow in the pull mode. Nothing came up on that to date.
Also a freind up the lake is interested in a tractor and implements. He is getting older as we all are and has had back troubles. He would most often like to pull a snow blower than push it? He doesn't want to be looking back too much.
Many have said they like the Pronovost but none have had one with the inverse option. I will give them a call and find out what I can. Sounds like the Meteor is an OK unit as well.
/ snow blowers #14
Talking about pull units or inverse blowers: Pronovost and Normand are excellent brands and well built. Many contractors around here run them and have for years. Mine is a Smith (see link several posts above for pics.) Another pretty solid machine but I did do some fine tuning to it. Meteor seemed to be a much lighter blower.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2014 Kawasaki 70Z7 Articulated Wheel Loader (A61572)
2014 Kawasaki 70Z7...
2007 Ford Crown Victoria Sedan (A61574)
2007 Ford Crown...
1073 (A64280)
1073 (A64280)
