Snow Blade
/ Snow Blade #21
When the ground is not frozen, wet snow alone will pick up gravel and the shoes on my plows will trench a soft driveway.. Sorry to hear that the metal pipe does not work for you. A while ago, I tried PVC as a test and it seemed to work ok for one season. I then did black iron pipe and it worked ok for the 2 times I used it but then I sold that tractor and plow.
dn
/ Snow Blade #22
I plow 3-4 parking spaces that are small crushed limestone. The wheels help tremendously, as I can curl the blade back onto the wheels and keep it anywhere from 0 to about 6" above the gravel. I also plow my neighbor's gravel driveway. It's about 110' long. Same deal, just curl it back so it rides a couple inches off the ground.
/ Snow Blade #23
I use a poly cutting edge that is 1 1/2" thick and you don't use shoes or pucks or wheels on asphalt but on stone I use the weight transfer and it doesn't dig in on stone.... jim
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2016 PETERBILT 389 FLATTOP (A60736)
2016 PETERBILT 389...
Compressor (A55973)
Compressor (A55973)
2013 FORD F250 (A60460)
2013 FORD F250...
2018 Navigator RT-6500 6,500lb Piggyback Trailer Forklift (A59228)
2018 Navigator...
2018 Forest River Flagstaff 228BHSE Pop Up Camper Trailer (A59231)
2018 Forest River...
