Snow Blade
/ Snow Blade #21
When the ground is not frozen, wet snow alone will pick up gravel and the shoes on my plows will trench a soft driveway.. Sorry to hear that the metal pipe does not work for you. A while ago, I tried PVC as a test and it seemed to work ok for one season. I then did black iron pipe and it worked ok for the 2 times I used it but then I sold that tractor and plow.
dn
/ Snow Blade #22
I plow 3-4 parking spaces that are small crushed limestone. The wheels help tremendously, as I can curl the blade back onto the wheels and keep it anywhere from 0 to about 6" above the gravel. I also plow my neighbor's gravel driveway. It's about 110' long. Same deal, just curl it back so it rides a couple inches off the ground.
/ Snow Blade #23
I use a poly cutting edge that is 1 1/2" thick and you don't use shoes or pucks or wheels on asphalt but on stone I use the weight transfer and it doesn't dig in on stone.... jim
PORTA POTTY (A67714)
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
2012 PETERBILT 587 (A67714)
2012 PETERBILT 587...
1979 MERIT FUEL TRANSPORT TRAILER (A67714)
1979 MERIT FUEL...
