Snapper Will not Start
/ Snapper Will not Start #1
KoonHunter51
Marshall, NC
FarmPro (Jinma)2430
28" Hi-Vac Rider Starter engages but will not turn motor. I put on a new drive belt & clutch disc. Removed 1 engine bolt to get the rear belt guide off to put belt thru it, this bolt had 3 wires for ground, black wire from battery, and a smaller green & grown wires. I put new terminals on small wires & tightened bolt.
I also cleaned all the positive wiring terminals also.
Now no start but the starter engages but will not turn the flywheel.
Could this be a ground problem. ?
I also installed a new solenoid & same result
David
/ Snapper Will not Start #2
Try jumping directly to the starter, and ground cable directly to engine. If it still does not turn the motor, you may have to adjust the valves.
/ Snapper Will not Start #3
It always helps when asking an engine question to know what engine we are talking about, make, model etc. For example it is highly unlikely a valve adjustment problem with a flat head B&S engines, possibly with an OHV B&S engine, unlikely with a Kohler engine.
Walt Conner
Safety Switch under seat had bad connector.
I also rebuilt carb & adjusted valves (OHV Briggs)
Runs like new now,
2005 International 4300 Rollback (A62613)
2005 International...
E-Ton Viper RXL-50 FOURWHEELER (A62613)
E-Ton Viper RXL-50...
Skid Steer Bale Spear (A65640)
Skid Steer Bale...
WEILER P265 ASPHALT PAVER (A65053)
WEILER P265...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2008 HEARTLAND RV CYCLONE 40 FOOT TOY HAULER (A59914)
2008 HEARTLAND RV...
