snapped chain.....twice
   / snapped chain.....twice #1
Sumpter
Eastern Oregon
New Holland 3040 w/ cab and CVT
We have snapped the chain twice on the new blower. The shear bolts are Grade 5 - 5/16" which is recommended. Both times it has been a rock. I wonder it I need softer bolts or a stronger chain. My belief is that the bolt should shear before the chain breaks. The bolts broke the first time the chain broke but not the second time. Any suggestions?
   / snapped chain.....twice #2
"My belief is that the bolt should shear before the chain breaks."
Correct,once in great while chain will snap.
I would seek out stronger chain leave shear pins size as is also take walk about remover the bigger stones.
   / snapped chain.....twice #3
Rock are hard on chains.do you know if the chain is 60 or 60h.The 60h is a thicker and heavier chain.Mine has 60h.Any chain store should have some.Usualy if the chain breaks there is most likely a crack some where else or its streached.I always change mine .Chain is cheap
I do not know what chain I have. I will have to check it.
   / snapped chain.....twice #5
I don't know what make of blower you have but my Buhler/Allied has three shear bolts two are 5/16 (grade 8) that are on the shear plates built into the PTO shaft.
The third one is a 1/4 (grade 5) on the shaft driving the chain,thus protecting the chain and auger.
The reason I mention this is because I wonder if yours has a third lighter shear bolt in a rusted/stuck shear setup.
Dan
   / snapped chain.....twice #6
Yowee!!!!!!!
If you are snapping chains your tension MUST be too tight if the little brat is new.
Please forgive the question, but is the shear bolt actually a shear bolt with a weakened end with a cut in the pin?
You should be snapping shear pins not chain period.
The shear pin always always breaks and the roller chain is never a victim unless its old and worn out.
The rule of thumb is that the top flight of chain is taunt and the lower flight is just bit sloppy-about an eigth of an inch of slack as the chain is traveling in one direction only.:thumbsup:
The roller links will have the chain size stamped on the connecting links.
I would call the dealer after you look at the chain tension first as that is my first and foremost thought simply as to much tension will destroy a chain before the sprockets exibit any damage; as it should not snap if the 60H chain is of good SAE quality.
   / snapped chain.....twice #8
You're SURE you're supposed to use grade 5 shear bolts?
TGReaper.....The blower is a New Holland spec'd for that tractor. The tractor, blower and everything is brand new so nothing is wore out. I only have about 25 hours on the tractor and less on the implements.
LeonZ and Jake98.....The chain tension is set per the spec in the book and the shear bolt is just a regular 5/16 X 1-1/2 grade 5 bolt that you will find in any hardware store. This is the bolt that the specs call for.
I still need to see what chain I have when I get back home, but if this happens again I will be contacting the dealer to see what I am doing wrong or what my options are. At this time I have made sure I have some master links on the tractor.
The other thought is that I will eventually have all the rocks blown out of my path and won't have to worry about it anymore. :laughing:
   / snapped chain.....twice #10
I use 5/16 Gr5 fully threaded bolts. The threads give a shear point.
larry
RAKE ATTACHMENT FOR MINI EXCAVATOR (A53843)
RAKE ATTACHMENT...
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
