Smooth or notched cultipacker wheels?
   / Smooth or notched cultipacker wheels? #1
Buty
Canton, GA
Kubota L3200
Building a cultipacker and looking at two wheel options. Option 1: larger smooth wheels 17" OD x 3 3/4" wide and 24lbs each Option 2: Notched wheels are 9.5" x 2.28" wide weighing 8.2lbs each. Based on a 5' wide cultipacker, the smooth wheels add about 40% overall weight. Is weight the only factor that I need to be concerned with? Seems like the notched wheels are what most people are using these days. My only other concern would be part availability (if one breaks) for the smooth wheels whereas Agri supply stocks the notched ones. I would be using this cultipacker after a tiller for food plots such as clover or larger grains.
Smaller notched wheels
Larger smooth wheels
   / Smooth or notched cultipacker wheels? #2
If soil is highly prone to form hard clods which remain after one pass of a Disc Harrow, notched wheels are preferred to break them. Notched wheels are somewhat a specialty item.
As you prep with a PTO powered roto-tiller I recommend smooth wheels.
Most CUT tractor Cultipackers are sold with smooth wheels.
BRILLION offers a large number of Cultipacker wheel types for their Big Ag implements. I guess if one is spending $70,000 for a Cultipacker, it gives the Brillion salesman something else to talk about if discussion lags.
BRILLION LINK: Pulverizer
   / Smooth or notched cultipacker wheels? #3
Would the smooth wheels have a potential for sliding Vs turning if they encounter a large clod or stick?
   / Smooth or notched cultipacker wheels? #4
Not in my experience. Even the "smooth" wheels have a high ridge, which gives them a certain boat rudder effect. And, being of cast iron, they are heavy, so lots of rolling inertia. I think my 72" Cultipacker weighs 860 pounds.
Photos: everytthingattachments.com Cultipacker
Wow, interesting chart.
   / Smooth or notched cultipacker wheels? #6
You need both. Alternate the smooth and notched wheels. That way you keep damp soil from clogging the V's formed by the smooth wheels.
Here's my 10-ft wide cultipacker which is set up that way.
Good luck
   / Smooth or notched cultipacker wheels? #7
Until I seen that chart I wouldn't have thought there would be much difference. Not a good picture but the only one I could find right now. My Brillion has the notched wheels.
I am in cultipacker envy seeing all the nice equipment you guys have. Does the wheel O.D. size have anything to do with it? The 9 1/2" wheels would have less surface contact so...maybe pack same as a heavier unit?
   / Smooth or notched cultipacker wheels? #9
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
2013 BMW X5 xDrive50i AWD SUV (A50324)
2013 BMW X5...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2025 LandHonor DCM-11-250G Hydraulic Double Discharge Concrete Mixer Skid Steer Attachment (A49462)
2025 LandHonor...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
