Smooth or notched cultipacker wheels?
   / Smooth or notched cultipacker wheels? #11
For food plots, etc, I don't think you'll notice much difference between the types. I think you'll see a bigger difference in performance based on soil type and moisture between plots. If I were you, and had access to the old original wheels, I would be using them. Tried and true. I would also be sure to get a few replacements and store them for future use. I could use a few wheels, but haven't stumbled across any locally.
Looks like it will be the notched wheels since I just couldn't get to the used ones in time. Hopefully it will be heavy enough but I'm sure it will since they make a lot of them that way. Thanks for the replies.
   / Smooth or notched cultipacker wheels? #13
I think it will be fine. I add several solid cement blocks to my old cultipacker for extra weight, which helps too. It's really amazing the difference in germination when you use one. It doesn't look like it does much, but if there is any moisture in the ground, you'll get an instant start on germination compared to areas you don't roll. I usually double roll mine, in angled or perpendicular directions.
Case Ih 2388 Combine (A50514)
Case Ih 2388...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
2018 CAT 320GC Excavator (A47384)
2018 CAT 320GC...
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
