Smooth loader bucket vs stump
   / Smooth loader bucket vs stump #41
Weights put the weight on the tractor, fluid puts the weight on the ground.
I think I'm going to start a stump bucket thread since that is what this turned into and I can't find any decent ones on TBN. I thought about getting a stump bucket a long time and the opinions are very polar. I think there are good reasons why the are polar and we need a thread that explains those reasons so those thinking about a stump bucket have a good source to inform their decision.
   / Smooth loader bucket vs stump #43
I wonder if this would work on my tractor loader ??? I have an Kubota 1153 loader on a Kubota M7040... Loader has the quick attach...
Considering that your tractor is heavier than mine it should have no problem pushing a stump bucket into the ground. I don't know anything about the curl cylinder on your loader. Given the size of the tractor I would think they are decent, but this is just a guess. Do you have specs on the loader especially curl force? Alternatively if you have curl cylinder specs (length, diameter, rod diameter) and the hydraulic relief pressure setting on you loader we'd have an idea of how strong the curl is. I'm guessing it would work fine. Just don't drive forward with the bucket tilted all the way down into the ground.
I just started a new thread on stump buckets. You might want to join that discussion.
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
flooring (A55758)
flooring (A55758)
2014 Ford F-150 Pickup Truck (A55973)
2014 Ford F-150...
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
BED FROM 2024 FORD F250 SUPER DUTY (A58018)
BED FROM 2024 FORD...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
