Smart Shop tips!
/ Smart Shop tips! #301
BUT DO NOT USE THE SPRAY ACCELERATOR!
I cut my finger bad one evening earlier this year but waited to go into the doctor until the next morning. The doctor looked at it and said it was really too late to stitch it up and used some 'medical' grade CA. A day later I was back in my shop and accidentally opened the wound up grabbing something and decided to self doctor using my own CA. Hurried the process using the spray and OMG! That stung!
I used the thin CA that sets almost instantly, so I didn't need to use accelerator.
I don't think I would have sprayed accelerator on an open wound though.
/ Smart Shop tips! #302
In my shop wall space is scarce so my chains are kept in a plastic 15 gallon container with the top cut off. Chains inside the container, binders on the outside. Makes them easy to keep track of.
/ Smart Shop tips! #303
Perhaps not shop per se'..... but when I open a bottle (gallon) of bar oil for my chainsaws, I take the cap off but instead of taking the seal under it off, I punch a hole in it with a Phillips so now I have a much more controlled flow of oil into the saw.
I use old dish soap containers and fill them with bar oil. Easy to hit the target and no drip lid you'll never set down in the woods and loose. On the down sight UV light tears them up so they're really only good for about a season.
/ Smart Shop tips! #304
Most probably know this already but if you are needing to find the center of round stock to drill a hole, the quickest way I have found is to use a ruler or something straight on top of the round stock, then place the drill bit on top of the ruler. As the material is moved back and forth, the ruler will rock from side to side accordingly. Once the ruler is straight you are in the center of the material, or at least close enough for most purposes. The same can be done on a lathe to get the cutting bit in center.
View attachment 682151 View attachment 682152 View attachment 682154
I've done that trick on a mini lathe, but never thought to use it on a drill press. THANKS!
/ Smart Shop tips! #305
HaHa!
That is exactly how I store my tire chains off season.
Bonus is that they are never tangled either.
The bucket sits outside with a plastic domed hood to shed water.
/ Smart Shop tips! #306
HaHa!
I don't know where to find 15 gal. plastic containers.
/ Smart Shop tips! #307
HaHa!
That is the nice part of storing them that way, they don't get tangled so they are easy to pull out. And it is easy to see which chain I want.
/ Smart Shop tips! #308
I'm not sure how to help you on that. I get them at work so they are free. I have two, one for chains, the other for diesel fuel.
I suppose the 15 gallon steel containers would work just as good but you may have to smash down the folded lip at the top if it is too thick for the hooks.
/ Smart Shop tips! #309
Big heavy duty trash can or steel barrel should work. Chains I spray different bright colors every few feet so I can find them!
/ Smart Shop tips! #310
AWESOME POST!! Some great ideas here as I dial in my new shop. THANKS!!
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
2016 Dodge Grand Caravan SE Plus (A59231)
2016 Dodge Grand...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2020 DITCH WITCH HX30 TRAILER VACUUM TRAILER (A59823)
2020 DITCH WITCH...
Kuhn FC400RG (A60462)
