Smart Meter rant- technology going Backwards!
/ Smart Meter rant- technology going Backwards! #61
Just the beginning.........I read an article these smart readers will be able to tell the electric company which appliances are running and when they run. Will decide if your using to much electricity and soon enough they will be in control of when you can wash and dry your clothes. Just like the thermostats that can be controlled by the electric company.
I can go online and see a pie chart showing what the electric company claims is the amount of electricity used for:
Water Heating
Heating
Appliances
Refrigeration
Electronics
Lighting
Cooling
And of course, I have no idea how they can tell that, but I guess they can.
/ Smart Meter rant- technology going Backwards! #62
My brother has A/C and maybe uses it one week a year... it was in the home when he bought it.
When the smart meter was going in the installer told him the Utility would pay him $25 if my brother would also have a utility controlled A/C switch installed at the same time.
My brother did and got his $25 credit.
Over the summer, there were a couple days of record heat... he calls me and says the A/C doesn't work and assumed it was the switch... after speaking with the Utility he learns it should be working some of the time..
I go and take a look and find the wire to his thermostat was disconnected... there was no way it was ever going to work...
Electric utilities are good at running Pipes in the Sky (power lines), as they should be. Implementing broad scale automation technology across millions of installations - Not so Much.
They do have to be good at sub-station/grid automation technology, but most of that is hardly cutting edge (nor would I want it to be..... CtrlAltDel is not what you need on a power grid). There are specialized techs that deal with this in-house utility technology, but it is rather narrow in focus, and evolves pretty slowly (again, a good thing, IMO). Those techs are just a tiny percentage of the total utility head count, so you can't just grab them and start rewiring houses in bulk.
I don't see load shedding at the household level as being easily implemented, nor all that effective.
Rgds, D.
/ Smart Meter rant- technology going Backwards! #63
Water Heating
Heating
Appliances
Refrigeration
Electronics
Lighting
Cooling
With the right sensors in place, all that detail can be monitored - technically, it is not that hard to do. You may find this level of reporting in a modern industrial plant, or LEED certified building, but as far as I know, it's never been routinely installed at the residential level (Canada/USA).
I suspect these are just estimates from your utility Bird, perhaps put forth to help get people to accept Smart Meters.
Rgds, D.
/ Smart Meter rant- technology going Backwards! #64
Of course, I sure don't whether that's right or not, but I have no doubt at all that you know more about it than I do, and just estimates certainly wouldn't surprise me.
/ Smart Meter rant- technology going Backwards! #65
This is a very expensive system to maintain by the utility. You probably read about a pilot program where the customers house was equipped with controllers and sensors wired to a CPU and downloaded on a regular basis. These pilot programs are usually voluntary and the customer gets a slight break if they abide by the TOU standard set by the utility. The term "smart meter" is very broad but usually used for "Time Of Use" billing. There are usually electronic my nature although there are electromechanical retrofits for residential use. A deemed smart meter cannot tell if the load is HVAC or a Water Heater without proper remote sensors wired throughout the home.
The whole benefit from "smart meters" load monitoring is to prevent power provider brown outs and conserve power is high populated areas where power is brought in over the nationwide power grid. If the home is smart wired. The utility can issue a command and turn your water heater off to shed load under an emergency situation. In all my years the utility I worked for never had to do that on commercial customers. we had that option available. They either comply or get severely penalized on their billing. This is a contracted agreement. Under extreme conservation measure these large industries if they did not comply the substation could shut them down remotely.
If the power company has the invested technology. They can read meters miles away from collection point thru "powerline carrier" which we have one on our house. It can record peek times here. These smart meters can record quite a bit of generic data. I was heavily involved with this technology before I retired both residential and commercial applications.
/ Smart Meter rant- technology going Backwards! #66
Water Heating
Heating
Appliances
Refrigeration
Electronics
Lighting
Cooling
I can see how the power company could guesstimate these values based on time of day electrical usage and assuming that the person works a first shift job. It may assume that loads 5-7 pm are involved with cooking appliances (stove and dishwasher) and loads at 10pm and/or 7am are water heating after a shower. A load at 3am on a 70 degree day/50 degree night would likely be refrigeration. Loads from 7-10 pm may be electronics. The lighting one seems like it would be tough to guesstimate- unless it "sees" a small load increase at 6am that drops off at 8am and pops back up at sundown.
Technically, if they literally recorded/analyzed every second of your usage, they could probably determine what day you usually do laundry, what time you go to bed/get up, they could likely even tell when you are on vacation... Big brother is watching an ammeter...
/ Smart Meter rant- technology going Backwards! #67
Neighbor was Plant Superintendent for a large industrial gas supplier.
They were one of the first with Load Shedding.
The offer from the Utility was too great to pass on.
They also did a lot of heavy power usage applications at night.
The savings were phenomenal too.
A few times they would get the call and have 15 minutes to shut down most processes.
The military also put in a rail line spir to the plant in the interest of national defense and stationed several rail cars there.
/ Smart Meter rant- technology going Backwards! #68
Maybe there were tractor thieves lurking, and she was just securing it ?
Even w/o horns, heavy animals can create a lot of equipment problems. One of the few times I saw my uncle pissed off was when I found the counter knocked off a baler - turns out the draft horses took a liking to rubbing against the baler.
Fun times ! Good memories, actually.
Rgds, D.
my horses like to bite and pull on things.
hoses.. buckets.. pails.. others halters.. etc..
/ Smart Meter rant- technology going Backwards! #70
And me! I've only been bucked off once, only had a loose cinch let the saddle slip and dump me once, only been kicked once, but been bit more times than I could count.:(
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
