Small trencher
/ Small trencher #1
dvan1966
NW. Ohio
Kubota B6200DT
I have a area in my backyard that has had standing water in it all winter. I need to dig a small trench to drain it. Any ideas on something on a 3 point hitch or attaching to the FEL to do this? I have a Kubota B6200.
Thanks for any advise.
/ Small trencher #2
A subsoiler with a mole-ball will make a hole for water to run in. It's the farmers "quick" tile job. But it will collapse if driven on, so you get to do it every year. John Deere makes one for farm tractors but with a little ingenuity you could patch one together for your B6200.
/ Small trencher #3
Backyard picture with the water would help. How big and long is the area? Do you really need a trench or to generally regrade or fill in a low spot? Do you need a french drain?
Just some preliminary questions that come to mind.
/ Small trencher #4
You need a pizza cutter
Mole ploughs only work in clay soil.
/ Small trencher
It's not a big area. I plan on getting topsoil and fill in. It has always soaked in in the past but the past year it holds water. It doesn't help that I have septic/leach field issues and a tile that drains in that area sometimes. The plan is to get all that fixed this spring. I just need to get it dried out. I also have a downed tree that I need to cut up in that area.
/ Small trencher
the area I need to drain
/ Small trencher #7
Better rear blades dig a swallow trench pretty good.
Quick spade on forks works good.
/ Small trencher #8
My back yard looked similar to that about 40 years ago. I took a round pointed shovel, removed a1 foot strip of sod, dug a shallow ditch. Laid in an appropriate length of slotted 4" or 6" black plastic drain pipe, laid a layer of roofing felt over, filled around the sides with #57, topped with the sod. Been fine ever since.
My back hurts just thinking about.
A tractor solution would have been nice.
/ Small trencher #9
Where would you drain that to and how deep would you have to go to reach daylight with the outlet of your drain?
Does the drain tile location feed water into this area that is ponding? Is something else going on that is causing your septic field to also be saturated with water?
Has this been going on for a while or did it recently start?
Sort of wondering if the three issues you mentioned are all connected and the ponding is just one symptom of an underlying cause or if you are dealing with multiple separate problems.
/ Small trencher #10
Looks like you have a high spot where that lane is. Need to cut it a bit lower there. Should be able to take your loader bucket and put the cutting edge down where you want the water to run and simply roll you bucket. Might take a couple of times to make it low enough for water to drain.
Or you could get a sub soiler and pull it through that drive area about 6-8" deep and water will flow. You won't need to add any attachment to the rear of it. Just pull it a few inched deep. Also, make sure you have to utilities in the path!!
/ Small trencher #11
A middlebuster is a wide version of a subsoiler, which would make a little wider trench. I used a rear pond scoop/dirt scoop to dig a ditch, which worked out really good.
David from jax
/ Small trencher #12
/ Small trencher
We made one at work the other day, seems to work pretty well. Just too muddy to get back where I want to trench right now.
/ Small trencher #14
Love to see homemade implements. I like the use of the 3pt drawbar. Whenever im daydreaming some kind of homemade attachment I always seem to forget that you don't have to build the lower pins mounting points if you just make the thing bolt to a 3pt drawbar.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
LIGHT PLANT GENERAC MAGNUM (NON TITLED) (A63569)
LIGHT PLANT...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2022 FORD F-150 4X4 (A63569)
2022 FORD F-150...
2011 WESTERN STAR 4900 SB MID-ROOF SLEEPER (INOPERABLE) (A63569)
2011 WESTERN STAR...
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
