small tree cutter
/ small tree cutter #1
potato chip
kubota L 3130
Has anyone built a 3-4 inch tree cutter powered by PTO that a kubota 3130 would handle. What about revising a rotary mower to add a slot for the tree to enter and a saw blade? Gravely used to make a walk behind unit that would do but this is no longer available. Maybe someone knows of a pto tree saw unit that can be purchased. I do not want to go to a hydraulic unit because of cost of adding the auxiliary valves.Thanks, I have a lot of small trees that need to be cut.
/ small tree cutter #3
Gravely used to make a walk behind unit that would do but this is no longer available..
I had one like this at the David Bradley site. It worked OK but only used it a couple times as a chain saw was faster because of more maneuverability. As you can see it was a pretty simple rig, run off the motor by a twisted belt over a couple idler pulleys. I should be easy to fabricate one to run off the PTO, maybe use a 90 degree drive rather than belt.
I wish I still had that old DB as it had many other attachments with it also including a front mount buzz saw, sickle bar and reel mowers, plow, disc and cultivator. I think I sold the whole shebang for about $20
/ small tree cutter #4
YouTube - Tractor Saw
I have been thinking of cutting a slot in an old brush hog and putting a big saw blade on it, I would also put some sort of push bar on it to put a little pressure on the tree as I am backing into it. It will be next winter before I am able to give any life to my idea though. The link above should give you some ideas.
2025 48in. Farm Jack (A61572)
2025 48in. Farm...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2007 Dodge Ram...
JCT 72" VIBRATORY ROLLER (A64281)
JCT 72" VIBRATORY...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2018 Ford F-350 Crew Cab Landscape Dump Truck (A61573)
2018 Ford F-350...
iDrive TDS-2010H...
