Small Engine Battery CCA Requirements
/ Small Engine Battery CCA Requirements #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
I need a battery for my JD LX279 riding lawnmower, the factory battery is 500 CCA, really???
I have a 160HP Yamaha that uses a 300CCA battery, a Kawasaki 24HP Cub Zero Turn that uses a 230CCA "cheap" mower battery, and for some reason JD says I need a $150 full size battery for a 17HP Kawasaki engine. As long as I can hook it up I am not concerned with a factory fit it is not like I am doing high speed maneuvers.
Any thoughts on the matter? I'm bored the wife is watching NCIS :)
/ Small Engine Battery CCA Requirements #2
A standard 300 CCA lawn mower battery is more than sufficient. I’m not a fan of the 230 CCA bargain lawn mower batteries, but one of them would do it as well.
Going to try the standard L&G 300CCA Battery
If anyone else is looking I just ordered one from TSC for $9.62, they are having an online special and I added a promo code SURVEYF5. It even has a 6-month warranty
Huskee Lawn Tractor Battery
SKU# 470899
HSK GTX 300CCA
/ Small Engine Battery CCA Requirements #4
In the winter, around here, if I had a 300 CCA battery in my M6040, it had better start the first time. It always has, but I don't know if there would be much left if I had to go for a second or third start attempt. And I really don't want to find out. I have a Group 31, Odyssey AGM, with 1150 CCA, Deltron battery tender and never worry about starting.
If I could get an adequate battery for $9.62 - I'd be going that way also. Very little to loose there.
TSC just cancelled my order, no reason. I assume they had a system error and didn't want to sell a $45 for $10.
/ Small Engine Battery CCA Requirements #6
The original battery in these lasts a good long time. You can match it at any auto parts store or convert the terminals and do a lawn and garden battery. As Rick noted, 300 CCA is a good size to shoot for. Maintenance free if you can.
/ Small Engine Battery CCA Requirements #7
I don't have to replace batteries that often in any of my machines. But when I do I always go for a battery with at least the same amount of CCAs or higher than the original that will fit in the battery compartment and make the connections without any alterations.
I want something long lasting and most of all dependable. ;)
/ Small Engine Battery CCA Requirements #8
U
That’s usually good advise, I’d give it AND follow it. But we are talking about a frigging 17 hp Kawi. There’s millions of engines of this size being started with 230-300 CCA batteries.
/ Small Engine Battery CCA Requirements #9
U
And the point of your comment is???? :confused3:
You added nothing of value to the O.P.'s question. Rather nothing of value, period. :rolleyes:
/ Small Engine Battery CCA Requirements #10
Your advise notwithstanding I think a $150 500 CCA battery for this application is overkill.
Do you understand now? You can review post #1 above.
Additionally there is an ignore option if my participation offends you. Have a nice evening.
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
(48) Closing Wheels off Great Plains Planter (A65640)
(48) Closing...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
(2) 13.50x60 Tires and Rims (A65640)
(2) 13.50x60 Tires...
2019 RAM LARAMIE 1500 (A65643)
2019 RAM LARAMIE...
