Small Deck Over?
/ Small Deck Over? #1
Haywire
Central Kentucky
Tractorless :(
All the deck over trailers I've seen are 14K+, 20'+ heavy equipment trailers. Has anyone ever seen a small trailer built as a deck over? I'm thinking axles normally used for a 5' wide trailer built deck over to make something like a 12x7 tandem 7K trailer.
Ian
/ Small Deck Over? #2
PJ makes a 5 inch channel frame deckover that I believe has 3500 lb axles.
/ Small Deck Over?
16' minimum length and 8'+ width... looking for something smaller. thanks though.
Ian
/ Small Deck Over? #4
Look at ATV trailers:
/ Small Deck Over? #6
Would a snowmobile trailer be large/heavy enough for your purposes? Just an idea.
/ Small Deck Over? #7
If you are thinking of hauling that little tractor in your Avatar forget it. You will get hung up with the brake over angle from the ramps to the deck because of the height.
You do know that the trailer you want is very special and 99 out of 100 buyers will not be interested in it if you ever decide to sell. Why not just a standard landscape or car hauler style?
Chris
/ Small Deck Over?
The idea was to get a large deck area in a small package. I don't like trailers that are wider than the truck pulling them. My 5x8 trailer is 80" wide. I need a minimum of 72" for the mowing deck and 12' in length for the tractor and implement or tractor with FEL attached. If I had a deck over, I'd have 80" of width in a package no wider than the 5x8 trailer I have now. Maybe I'd just have a beaver tail built into the ramps to cut that angle down into two steps.
Ian
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2014 F-150 4WD (A63688)
2014 F-150 4WD...
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
2005 Chevrolet Impala Sedan (A61574)
2005 Chevrolet...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
