sluggish 3ph
/ sluggish 3ph #1
gsgator
FL Suncoast
Branson 2910
Does anyone else experience slow response from the 3ph? My 2910 has about a 3-5 second delay, which makes it frustrating for grading/etc. This model does not have the separate pump like the "i" models. Is this the reason for the delay?
/ sluggish 3ph #2
Have you turned the dial between you legs all the way to your right?
The dial adjust how fast the 3pt will drop.
/ sluggish 3ph #3
As Wallace said, try the round knob. It allows you to taylor the speed of the 3ph to your varios implements. I have used it to slow down the lift for my auger and to speed it up for mowing.
/ sluggish 3ph
I have adjusted it all the way to "fast", can't remember if that's right or left. Maybe I need to play with it a little bit and see if it makes a difference either way. Maybe the adjuster isn't adjusting. Forgot about that. Thanks.
/ sluggish 3ph #5
Mine is all the way to the right and is still kinda slow. Maybe that is just the way it is.
/ sluggish 3ph #6
GSGATOR; I have a alice chalmers that will slow down when water gets in the hydralics. I have not let my Branson sit out so I don't know if water will enter the system. My 3820 has worked great so far, except for white smoke on start!!!
I will clean filter to correct problem on A.C..
Question for you; do you shrimp over around Daytona???????
As always thanks for help; and to all that is looking for a Branson, come by and check out my 3820...
tnaz
/ sluggish 3ph
I live in Myakka City, which is about 180 miles south of Gainesville. I'm not to sure about shrimping in Daytona although a friend of mine just came back from there with about 25 pounds of shrimp from a commercial fisherman. When I was a kid, my dad used to take us shrimping in southern Sarasota County, but I don't think the shrimp come through here like they used to. When I lived in Gainesville, we used to go to Horshoe Cove and catch snook. You ever go there?
/ sluggish 3ph #8
Hey GSGATOR;
Yep, I have fished Horseshoe, up to Steinhatchee and down to Yankeetown-Crystal River; but I shore aint no pro at catchin!!!!
I don't know why I thought you were from the Daytona area, sorry about that.
How about that tractor, did you get the lift figured out?
tnaz
PORTA POTTY (A68842)
GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
GENERAC MOBILE...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2022 Ford F-150...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
