sluggish 3ph
/ sluggish 3ph #1
gsgator
FL Suncoast
Branson 2910
Does anyone else experience slow response from the 3ph? My 2910 has about a 3-5 second delay, which makes it frustrating for grading/etc. This model does not have the separate pump like the "i" models. Is this the reason for the delay?
/ sluggish 3ph #2
Have you turned the dial between you legs all the way to your right?
The dial adjust how fast the 3pt will drop.
/ sluggish 3ph #3
As Wallace said, try the round knob. It allows you to taylor the speed of the 3ph to your varios implements. I have used it to slow down the lift for my auger and to speed it up for mowing.
/ sluggish 3ph
I have adjusted it all the way to "fast", can't remember if that's right or left. Maybe I need to play with it a little bit and see if it makes a difference either way. Maybe the adjuster isn't adjusting. Forgot about that. Thanks.
/ sluggish 3ph #5
Mine is all the way to the right and is still kinda slow. Maybe that is just the way it is.
/ sluggish 3ph #6
GSGATOR; I have a alice chalmers that will slow down when water gets in the hydralics. I have not let my Branson sit out so I don't know if water will enter the system. My 3820 has worked great so far, except for white smoke on start!!!
I will clean filter to correct problem on A.C..
Question for you; do you shrimp over around Daytona???????
As always thanks for help; and to all that is looking for a Branson, come by and check out my 3820...
tnaz
/ sluggish 3ph
I live in Myakka City, which is about 180 miles south of Gainesville. I'm not to sure about shrimping in Daytona although a friend of mine just came back from there with about 25 pounds of shrimp from a commercial fisherman. When I was a kid, my dad used to take us shrimping in southern Sarasota County, but I don't think the shrimp come through here like they used to. When I lived in Gainesville, we used to go to Horshoe Cove and catch snook. You ever go there?
/ sluggish 3ph #8
Hey GSGATOR;
Yep, I have fished Horseshoe, up to Steinhatchee and down to Yankeetown-Crystal River; but I shore aint no pro at catchin!!!!
I don't know why I thought you were from the Daytona area, sorry about that.
How about that tractor, did you get the lift figured out?
tnaz
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A67714)
2017 FORD F-150...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
PALLET OF MISC WHEELS (A67714)
PALLET OF MISC...
