SLOW HYDRAULICS
/ SLOW HYDRAULICS #1
parkie456
Moody TX
Branson 3510
I am having problems with my hydraulics on a Branson 3510 operating pretty slow. I have changed the hydraulic filter with little improvment. Is there a strainer or somthing else located somewhere on the under carraige that needs to be cleaned or replaced? Appreciate your help.
/ SLOW HYDRAULICS #2
I was having the same problem with a Branson 2910. The replacement filter was a Napa Gold 51202. The filter on it was probably the original filter since maintenance was not the previous owners strong point. When I put the 51202 the hyd. worked very slow, jerky or not at all if it was cold. The specs on the 51202 were 5 micron and paper filtering media. I looked on the WIX site and found 51205 filter with wire screen filtering 30 micron and 28 to 30 gpm. Put this on and hyd. work as they should. After reading a lot of post it seems some filters might be to tight on filtering with paper media. I do know that 5 microns is very small. Usually things in the 5 and 30 micron would be used in polishing compounds. Hope this helps it was the solution I found to poor hyds. 51205 filter is shorter.
/ SLOW HYDRAULICS
I appreciate the help very much I Put a WIX 51202 on when I changed it. I will get Wix 51205 and give that a try. You never know unless you ask that is why this is a great site. Have a great day..
2008 Ford Ranger Ext. Cab Pickup Truck (A59230)
2008 Ford Ranger...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2024 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2024 UTILITY VS2DX...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59905)
2020 FREIGHTLINER...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
