SLOW HYDRAULICS
/ SLOW HYDRAULICS #1
parkie456
Moody TX
Branson 3510
I am having problems with my hydraulics on a Branson 3510 operating pretty slow. I have changed the hydraulic filter with little improvment. Is there a strainer or somthing else located somewhere on the under carraige that needs to be cleaned or replaced? Appreciate your help.
/ SLOW HYDRAULICS #2
I was having the same problem with a Branson 2910. The replacement filter was a Napa Gold 51202. The filter on it was probably the original filter since maintenance was not the previous owners strong point. When I put the 51202 the hyd. worked very slow, jerky or not at all if it was cold. The specs on the 51202 were 5 micron and paper filtering media. I looked on the WIX site and found 51205 filter with wire screen filtering 30 micron and 28 to 30 gpm. Put this on and hyd. work as they should. After reading a lot of post it seems some filters might be to tight on filtering with paper media. I do know that 5 microns is very small. Usually things in the 5 and 30 micron would be used in polishing compounds. Hope this helps it was the solution I found to poor hyds. 51205 filter is shorter.
/ SLOW HYDRAULICS
I appreciate the help very much I Put a WIX 51202 on when I changed it. I will get Wix 51205 and give that a try. You never know unless you ask that is why this is a great site. Have a great day..
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
New/Unused Electric Winch (A65583)
New/Unused...
Metal Shell Statue (A64127)
Metal Shell Statue...
1998 International Loral (A64126)
1998 International...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
RHINO 127 - 7' OFFSET DISC HARROW (A64277)
RHINO 127 - 7'...
