ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,499
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
My L4400 has a 1495 Rhino FEL. I've always thought it was a bit slow. Doesn't like to curl and lift at the same time. Even slow when lowering the empty bucket.
My Brother recently purchased an L3240 with Kubota loader. His loader is twice as fast as mine. My cylinders are a little bigger than his. Both use a Joystick. Both use the same size hose to feed the controller.
Could it be the flow rate of the controller?? I suspect a flow rate problem by it being slow to lower.
Any ideas?? Thanks in advance.
