Slip Scoop
/ Slip Scoop #1
MaineGuy
Bronze Member
Vassalboro, Maine
1981 Ford 1200
I've got a few yards of loam and crushed stone to move around the yard and would like to buy a medium duty 3ph scoop to move it. The tractor is quite small, Ford 1200, so I'd want a small size scoop. I checked with a couple local tractor dealers and they don't sell them. One had never heard of such a thing. Northern Tool sells them for $275.00 with shipping. Not a bad price if it's more than a tin can. Does anyone have any experience ordering from Northern Tool or other places that sell and ship. Shipping to Maine will cost about as much as the scoop. Those things must weigh 150#- 200# or so.
Thanks for the input
David
/ Slip Scoop #2
David,
Here's a discussion from a couple of years back. I think the Northern scoops are made by Howse, and are a little lighter than the KK scoops you can get through Tractor Supply (if you have access to TSC).
Here's a link to the Howse web page, and here's the KK web page.
/ Slip Scoop
Bill, I'll check the sites you provided. There isn't a TSC in the area so ordering and having it shipped is my only option.
David
/ Slip Scoop #4
I bought a 3PH scoop for my Ford 1210 several years ago when I had to move a lot of topsoil and fill in along a new driveway. I forget the price, but it was inexpensive (at Central Tractor).The Ford handled it OK, but it was possible to do "wheelies" if I got too much dirt in the scoop. This was with two front suitcase weights in place..................chim
/ Slip Scoop
CHIM
I have the max suggested 3 weights up front, I will add more if needed and I think it will be needed. Would you think the 24in is best for the 1200? The prices are ok but I would like to find a local supply but living in Maine it's not likely.
Do you still use the 1210? Is that the 3cyl with power steering, what about a fel. Any problem with parts? I bought mine for mowing but have also pulled up some good sized rocks and mid sized logs for fire wood.
Thanks,
David
/ Slip Scoop #6
I bought a 24" scoop from Nothern Tool. I use it behind a JD 445 garden tractor/lawnmower. I changed the pins to cat. O. I'm amazed at how well it worked, especially behind such a small machine. My only concern was the height of the 3 point hitch above the ground. If I shortend the adjustment for the lift arms there was just enough height to dump the scoop. It was a stronger box than I expected. I picked it up at a Northern Tool store and saved the shipping cost. It does appear to be the same as the Howse scoop.
/ Slip Scoop #7
I don't remember the size I bought (and I have it stored in my Mom-in-law's barn). If I recall, it was around $250 at CT about 6 years ago. It was a pretty handy item. I dug a swale along the one side of my property with it. The project took a while, but it was fun. Varying the length of the toplink easily changes the angle to make it more or less aggressive-cutting. I bought my 1210 used, and 2 weights were what came with it. For everything but the scoop, 2 are enough.
My 1210 is is 4WD/HST 3-cylinder 16HP diesel and lacks loader and power steering. I still have the 1210, although the original plan was to sell it about 2-1/2 years ago when I bought the B7500HST w/ FEL. I mow about 7 acres, so both the Ford and Kubota have 5' RFM's. I keep the Ford on site where I mow about 5 of those acres, and drive the Kubota there so #3 Son and I can double-team it. He calls the Ford a "dinosaur" and much prefers the B7500 with power steering.
Parts have never been a problem. When I painted it a couple years ago, I replaced some steering parts and controls decals. The nearby Ford dealer has some parts in stock, and can get whatever else is needed in a couple days.
/ Slip Scoop
I read the old discussion that Bill linked for me and it seems like everybody that has used a scoop had a good experience with it no matter the brand.
I'll order one tonight. But I still hate to pay $95 for shipping.
/ Slip Scoop #9
</font><font color="blue" class="small">( But I still hate to pay $95 for shipping.
Thanks )</font>
If it's being shipped freight, you can have it delivered to any business address and the shipping will be considerably cheaper. I have stuff shipped to a friends dog grooming shop and she calls me when it's in. Works pretty well.
Also, if you ask, you may find that you can pick it up at the Depot and save some money that way.
If harbor freight won't work this kind of deal, you might find that others will. The lowest price isn't always the lowest cost.
Cliff
/ Slip Scoop #10
I have the King Kutter 30" scoop and use it with my 1700 to good effect... I think the 24" would be just right for your smaller tractor.
/ Slip Scoop #11
hi dave,
don't know were you are in maine, but i was up to eddie nash's place in colebrook nh and he had a couple of scoops
i bought a tiller and post hole digger from him[ her, his daughter] and found the prices to be very good the number up there is 603-237-8857, its worth the trip just to look around the guy yard must be 5 acres of machine of all types there
chris smith
porter maine /forums/images/graemlins/smile.gif
/ Slip Scoop
Chris,
I think I drove past there on a recent trip to Montreal. It's a bit of a hike but might be worth a look. I'll give them a call. Thanks for the info.
I'm over in Vassalboro.
David
/ Slip Scoop #13
You might ask you dealer, if he can get one. Most dealers don't carry every implement in stock, from every supplier that services them.
/ Slip Scoop
You're correct about dealers not being able to carry everything. Especially such a small item that is not a big seller. However when I called the NH dealer, where I bought my tractor, the person I spoke with said he had never heard of a slip scoop, rear scoop, 3 point hitch scoop or pond scoop. He did not offer to find one or ask someone else about the scoop. Was it because I only want to spend $200 and not $20,000? I hope not.
/ Slip Scoop
I found a local dealer who sent me to his local supplier/warehouse. Picked up the scoop yesterday. It is sold under the name Worksaver S-1030. It looks like the Howes 30". I started making the modifications pretty much the same ones made by and discussed in past TBN posts. The experience of others really helped me. I first cut the front corners so the lift arms wouldn't hit. Then I filed the lever catch arm thing. Next will come the heavy spring to assist with the dump release when the weight is in the front of the scoop and a release arm extension to replace the rope.
Although the scoop works fine and I moved a few yards of loam last night it might not be able to keep up with Schooner, my Bernese Mountain Dog, who take the dirt out of the holes faster than I can fill them.
Thanks again for the wisdom.
David
KUBOTA L3130 TRACTOR (A62130)
KUBOTA L3130...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
LOOK! (A63109)
LOOK! (A63109)
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
UNUSED MGY-100KW FUEL HEATER (A62131)
UNUSED MGY-100KW...
2017 CATERPILLLAR 938M WHEEL LOADER (A62129)
2017 CATERPILLLAR...
