Slip clutch
/ Slip clutch
then ill back them off anyway tonight and check that the clutch is in fact free.
/ Slip clutch #22
Too Loose will be a problem when you cut
Too tight will be a HUGE problem like Jerry said if you hit something where the clutch should slip and it doesn't.
I had to hunt down instructions on how to adjust the slip clutch. The original manual I received when I bought the RC did not have detailed inst. on adjustment. So I bugged Brown Mfg until I got what I needed.
If you have only grass to mow and will never hit anything larger or solid then don't worry about it. Most of us hit have hit something at one time or another that sheared a pin, slipped the clutch, or broke something.
/ Slip clutch #23
Around here we are constantly hitting fireant mounds and they will shear the grade#2 x 1/2" diameter bolts on a very regualr basis which is why it was replaced with the slip clutch setup.
/ Slip clutch #24
I adjust my slip clutch per the following:
1. back the tension off to a very low value.
2. put on my implement of destruction.
3. Let it slip for a few turns.
4. Tighten each of the 8 bolts one turn.
5. Let is slip again and repeat until it holds.
6. Tighten 1 1/2 turns.
Seems to work out well.
/ Slip clutch #25
One thing to look at. How is the clutch attached to the gearbox input shaft? a key or bolt/ Are they intact?
soundguy
/ Slip clutch #26
If yours is a 55hp rated Eurocardan, this chart might help.
//greg//
AR500 Coyote Target (A65640)
AR500 Coyote...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2022 Keystone RV Coleman Camper Trailer, VIN # 4YDTCMN20NH931920 (A65563)
2022 Keystone RV...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2 Row Cultivator (A64047)
2 Row Cultivator...
