Slip clutch
/ Slip clutch #1
normde2001
Elite Member
After reading the "pto shaft adj." repost, (thanks Brett), wondering if my "overrunning clutch" also has "slip clutch" capabilities, or do you get one or the other? If no slippage, where is the shear pin located for a rotary mower?
Norm
/ Slip clutch #2
<font color=blue>...wondering if my "overrunning clutch" also has "slip clutch" capabilities...</font color=blue>
No...
<font color=blue>... where is the shear pin located for a rotary mower?...</font color=blue>
Shear pins/bolts are usually located at the input shaft on the implement gearbox...
/ Slip clutch #3
<font color=blue>.."overrunning clutch" also has "slip clutch" capabilities...</font color=blue>
On the extreme duty rotary cutters {like a tree cutter or stuff that does 6-8" cutting}, they usually have a "Combo" slip clutch/overrunning clutch assembly that does both functions...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
(2) STACKS OF APPROX (50) EACH OF 24" X 112" (A64280)
(2) STACKS OF...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
