Slip clutch
/ Slip clutch #1
normde2001
Elite Member
After reading the "pto shaft adj." repost, (thanks Brett), wondering if my "overrunning clutch" also has "slip clutch" capabilities, or do you get one or the other? If no slippage, where is the shear pin located for a rotary mower?
Norm
/ Slip clutch #2
<font color=blue>...wondering if my "overrunning clutch" also has "slip clutch" capabilities...</font color=blue>
No...
<font color=blue>... where is the shear pin located for a rotary mower?...</font color=blue>
Shear pins/bolts are usually located at the input shaft on the implement gearbox...
/ Slip clutch #3
<font color=blue>.."overrunning clutch" also has "slip clutch" capabilities...</font color=blue>
On the extreme duty rotary cutters {like a tree cutter or stuff that does 6-8" cutting}, they usually have a "Combo" slip clutch/overrunning clutch assembly that does both functions...
2013 CHEVROLET CAPRICE CAR (A66091)
2013 CHEVROLET...
Lift (A64553)
Lift (A64553)
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2000 Generac SG068 75kVA Natural Gas Generator (A66734)
2000 Generac SG068...
2006 MACK CHN613 (INOPERABLE) (A67714)
2006 MACK CHN613...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
