Slip clutch torque
/ Slip clutch torque #1
ChadWS
Okla.
Framtrac 320DTC
Can any one tell me how much ft.lbs of torque i should put on the bolts of a slip clutch for a king kutter 5 foot tiller the tractor pto is 28.5
thanks Chad
/ Slip clutch torque #2
If it's a 55hp rated EuroCardan like mine, the adjustment specs are attached. Extrapolating from the chart, I'd adjust the springs to 28.1mm for your 28.5 PTO hp.
If it's a Bondioli, I can't help.
//greg//
Thanks Greg i think it is a Bondioli the paper work that came with it says to turn the nuts evenly thats hard to do with the tiller hooked up to the tractor was hoping i could use a torque wrench.
/ Slip clutch torque #4
Sorry - can't help you then. On mine, I adjust the spring tension bolt with a wrench in one hand, while I measure the spring length with a caliper in the other hand. I do this eight times, and I'm done. Oh, but before I do all that - I back them all off, dissassemble the clutch, and clean the friction plate and disks. Conventional wisdom suggests that be done twice a year if your clutch sits outdoors, in practice I only get around to it once.
//greg//
/ Slip clutch torque #5
greg_g said:
........but before I do all that - I back them all off, dissassemble the clutch, and clean the friction plate and disks. .......
That's the best advice there is on pto clutches. They change slip torque a lot with a little corrosion. I had one on a rotary cutter that looked great from the outside but was actually really stuck - there was a 1/2" bolt in the pto shaft coupling that sheared instead (good thing).
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
JOHN DEERE 5090 EL TRACTOR (A65057)
JOHN DEERE 5090 EL...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
Steiner TL348 50in Rotary Tiller Tractor Attachment (A64553)
Steiner TL348 50in...
2018 MACK PINNACLE (A67714)
2018 MACK PINNACLE...
