Slip clutch on my brush cutter
   / Slip clutch on my brush cutter #1
sgipson
south mississippi
ford 3600 1974
Hit stump with cutter today and smoked the slip clutch and the blades would not turn.
Can i tighten the bolts on the slip clutch assembly and correct the problem?
Appears to have about one quarter inch of material left.
   / Slip clutch on my brush cutter #2
Yes, that is the method for adjusting. But that is a big gap. Any rust on the adjusting bolts/nuts?
Should have a manual that gives the adjusting procedure.
   / Slip clutch on my brush cutter #3
I ended up spending about $20 for two new fiber discs and replaced ours for a like new job. One side on one was "frozen/rusted" to the metal part so there were only 3 surfaces that could slip.
   / Slip clutch on my brush cutter #4
Its possible when you hit the stump that you also still did damage to your gear box and it locked up. Can you turn the gear box by hand?
   / Slip clutch on my brush cutter #5
Tightning should do the trick. If you need slip disc pads, we have a pretty good supply. Ken Sweet
2008 Genie S-65 65ft Telescoping Boom Lift (A50322)
2008 Genie S-65...
2020 Chevrolet Express (A50120)
2020 Chevrolet...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2018 Land Rover Range Rover Supercharged 4WD SUV (A50324)
2018 Land Rover...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
