Slip clutch on my brush cutter
   / Slip clutch on my brush cutter #1
sgipson
Member
south mississippi
ford 3600 1974
Hit stump with cutter today and smoked the slip clutch and the blades would not turn.
Can i tighten the bolts on the slip clutch assembly and correct the problem?
Appears to have about one quarter inch of material left.
   / Slip clutch on my brush cutter #2
Yes, that is the method for adjusting. But that is a big gap. Any rust on the adjusting bolts/nuts?
Should have a manual that gives the adjusting procedure.
   / Slip clutch on my brush cutter #3
I ended up spending about $20 for two new fiber discs and replaced ours for a like new job. One side on one was "frozen/rusted" to the metal part so there were only 3 surfaces that could slip.
   / Slip clutch on my brush cutter #4
Its possible when you hit the stump that you also still did damage to your gear box and it locked up. Can you turn the gear box by hand?
   / Slip clutch on my brush cutter #5
Tightning should do the trick. If you need slip disc pads, we have a pretty good supply. Ken Sweet
2017 CHEVROLET 2500 HD (A50854)
2017 CHEVROLET...
Target Econline 2 Concrete Saw (A49461)
Target Econline 2...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
1996 Elgin Pelican Series S Street Sweeper (A50322)
1996 Elgin Pelican...
