Slightly Overloaded!!
/ Slightly Overloaded!! #1
HHR
Platinum Member
Northern MN
1997 Daewoo Dsl 801
1980 F700
23,100 GVW
Wood floored flatbed with hoist.
Mostly birch and maple that has been laying on the ground for a year.
What do you think the load weighs?
More photos.
/ Slightly Overloaded!! #3
Slightly more than that truck is rated for.
/ Slightly Overloaded!! #4
30,000# Did you have it weighed?
Chris
I have no idea what the truck weighs. It's a friend's truck and no scales were employed.
/ Slightly Overloaded!! #7
Primary question : Did he make it to his destination?
/ Slightly Overloaded!! #8
Here is Arizona and Ca. Mexican come up here and take apart homes board, by board, by board and load them on pick up trucks an haul the wood back to Mexico.
Some day I'll shoot a picture with these things piles so high I wonder how they get under bridges.
The front tires are barely on the ground, yet I see one or two of these every few weeks.
Why they aren't pulled over every mile I don't know.
Yes! He makes a few trips a week (40-50 miles each way) loaded to the max. It's kinda scary.
/ Slightly Overloaded!! #10
Nothing falling off it ain't overloaded
/ Slightly Overloaded!! #11
40-50 miles would definitely be the max you'd want to go... And would want to stay away from the weigh stations the cops sit at or you'd be looking at a pretty hefty fine.
/ Slightly Overloaded!! #12
I assumed that this truck is purely an off-road truck, so I would have said: " Pile it higher!"
But 40-50 miles must be on some public roads.
By the looks of the truck (smashed fender, busted flatbed, load, CDL?, etc) it looks like a DOT officers wet dream. It has no rear tag though. Its gotta be an offroad truck. Right?
3 miles on the most rutted logging road I've seen and the rest is on public roads.
/ Slightly Overloaded!! #15
Legally, based on the 23,100lb GVWR, it's probably over loaded. However, depending on what axles, spring package, frame type, etc it might be well within what the truck was built to haul, no idea on the weight though.
/ Slightly Overloaded!! #16
Don't forget the missing lights in the back :D.
Aaron Z
/ Slightly Overloaded!! #17
My guess would be 32,563.4 lbs. I base this on the length of the shadow, devided by the depth of the snow, multiplied by 2.43. Or I could have just pulled it from my 4th point of contact and have absolutely no idea!:D
/ Slightly Overloaded!! #18
I think you'd probably be looking at about 425 to 450 kg/m3. So, if those were 8' logs stacked 6' high on a 20' truck bed, it would be about 11,000 to 12,000 kg or about 26,000 lbs.... the extra weight should improve traction, though.
BOB
/ Slightly Overloaded!! #19
Probably more than mine. This figured to be about 5,346# on the back of my '31. Weighed one tie at 243#- there are 22. Springs weren't even fully flat. Wish I could find the picture with telephone poles cut up about 14' long, stacked 2' higher than the top of the roof. When they got to the top of the cab, they pushed them way foreward, I'm assuming to keep the front wheels on the ground, because the load on her in the picture below made the front light, look at where the center of balance is.
I know that a handful of the logs weighed at least 1000 pounds because the hydraulic bypass was kicking in on the skid steer.
3Pt Backhoe (A66285)
2014 Nissan Sentra Sedan (A61574)
2014 Nissan Sentra...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
CRAFTSMAN RADIAL SAW - 10 BLADE OUT RIP (A64281)
CRAFTSMAN RADIAL...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
