Skidding Logs with tractor.
   / Skidding Logs with tractor. #41
This is the first time I am hearing about the blade stabilizing the tractor. I always thought it was just a blade in case you needed it or would keep winched logs from going under the tractor. The fact that the winch pulls quite high up had totally escaped me.
Good to know.
   / Skidding Logs with tractor. #42
BackRoad said:
But the 3PH does not really act like a wheelie bar on a dragster - there is no real mechanical block from the 3PH preventing a back flip? (That's a question, not a statement).
Not asking this to question the poster or cause conflict, but rather to accurately understand the dynamics on whether a blade on the 3PH will actually stop a back flip.
Yes... Once the 3ph tops out it will just sit there and spin...
But I wouldn't try it with smaller CUT/SCUTS, without the wider wheelbase...might still be chances of going over sideways.
I've pulled with mine...but puts a lot of leverage on front from the counterbalance...and not very versatile in tight spots in the woods.
   / Skidding Logs with tractor. #43
When I was clearing my lot I was giving away wood. I would cut it up into 4' lengths and anyone who wanted to come here could take it as is or cut it up into the size they wanted. My mother decided to help me out by telling a neighbor near her that I would sell rounds ready to be split. I did it but only once, since it was my mother, but even at roughly $100 a cord delivered it was a loss to me. It required me to do more cutting, loading into my dump truck, and the gas to drive there (3 trips for about 3 1/2 cords). That didn't include the loss of time that I could have been working on my lot. Since I didn't want to take the extra time stacking it to figure out how much was there I just loaded extra into the dump truck so I wouldn't short the guy. I figure 3 1/2 cords but it could have been 5 cords. Since then I just do firewood for myself and mother (she's in her upper 70s so she needs stuff split very small). I often see people around me who buy loads of logs and cut/ split it to sell but I can't see it being very profitable.
   / Skidding Logs with tractor. #44
   / Skidding Logs with tractor. #45
I have skidded a lot of logs from the bush using a 3pt receiver hitch similar to the picture in post #2, and a hook at the top link attachment point to hold the lifting chain..
You ALWAYS, ALWAYS skid with another chain to the tractor draw bar..
Our old woodsman neighbor estimated some of the logs were about the weight of the tractor.. Again... ALWAYS pull with the draw bar.. Only lift with the 3 point..
   / Skidding Logs with tractor. #46
Why not pull with the 3 point hitch?
Pulling from drawbar keeps both ends of log in the dirt. All of log in dirt actually, chain saw gets more dull, log more likely to snag a root or stump, log pulls harder, rear of tractor has less weight/traction to pull log.
I agree that you shouldn’t pull with 3 point (or 2 point) hitch with connection point raised higher than axle or tractor can do a backflip. I can see that when pulling with a boom pole, it’s almost impossible to pull from below axle, and flip danger increases.
...but aren’t tractor’s made for pulling with the 3 point hitch (plows for example)?
You missed the portion of LIFT WITH THE 3PH
The reason for pulling low is to keep all 4 tires on the ground.
Go find a farmer that has large ground engaging equipment (disc, land planes or others) these have hydraulic lift systems and are pulled by a drawbar not the 3PH.
You may still need front ballast pulling low, but you have at least kept the downward pulling force low.
   / Skidding Logs with tractor. #47
Back when we farmed 12 rows at a time, every planter and cultivator was 3pt. I do agree with pulling from the draw bar for skidding logs.
   / Skidding Logs with tractor. #48
I always used a back blade on the 3 point turn your blade backwards hook your chain to the rear of the blade.mine had factory holes where you adjust the angle of the blade I used one of those holes with a clevis .you dont have to worry about flipping over backwards if the log catches something if your blade is a foot off the ground while skidding your front end will only raise about six inches before the blade will come down and hit the ground and once you get a few pulled out you can shove them out of the way with the blade being turned around backwards. I strongly recommend never skid a log off the draw bar or any kind of implement that wont cone down to contact the ground stopping you from going over backwards because it will happen in a split second you won't be fast enough to push in the clutch to stop it from going over I used this method for thirty years without one having a close call going over backwards
The only issue with your reasoning process is that few compact and utility size tractors have any down pressure on the 3PH, so when you tip the tractor for the rear blade to contact the ground, the blade may slow your tip or may not. This is the very reason that so many people think a trailer mover is a great item and find themselves in trouble when they have light tongue weight or a unsecured load shifts rearward.
Just go out to your empty 3PH and lift upward, most folks are shocked at how easily it lifts!
   / Skidding Logs with tractor. #49
Then what is the “draft control” lever for the 3 point hitch for?
   / Skidding Logs with tractor. #50
Isn't that just how fast it falls downward once you move your 3-pt control lever down?
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
2005 John Deere 200C LC (A55272)
2005 John Deere...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
