Skidding Logs with tractor.
/ Skidding Logs with tractor. #22
Why not pull with the 3 point hitch?
Pulling from drawbar keeps both ends of log in the dirt. All of log in dirt actually, chain saw gets more dull, log more likely to snag a root or stump, log pulls harder, rear of tractor has less weight/traction to pull log.
I agree that you shouldn稚 pull with 3 point (or 2 point) hitch with connection point raised higher than axle or tractor can do a backflip. I can see that when pulling with a boom pole, it痴 almost impossible to pull from below axle, and flip danger increases.
...but aren稚 tractor痴 made for pulling with the 3 point hitch (plows for example)?
I have the same question. I have a drawbar between the two arms of the 3pt hitch and i often put the hitch down and back the drawbar under the end of the log and then throw a chain around the log to the drawbar with an open hook so it will lock tight. I do not lift the log much - just enough to keep the end from dragging in the dirt so it is well below the axle.
/ Skidding Logs with tractor. #23
I would like a 3pt winch but just haven't enough use for one. What I do is use the loader to lift the end of the logs and put a piece of firewood under them so wrapping a chain around them is easy if they are laying on the ground. If they aren't too heavy I'll even drag them a ways using the loader. I use the 3pt hitch when pulling them. Just don't try to get a running start and jerk them. The downside is they do get dirty. A log arch would help keep them up out of the mud but I probably only cut 5 or 6 trees a year for firewood. Half of them I'll buck up in place so it just doesn't make sense to get an expensive option to make it easier.
As for the "don't pull above the center line of the rear axle, I do it all the time. If you have a HST or shuttle shift I don't see it as much of an issue. A geared tractor, yes. Your foot could slip off the clutch and as the front comes up you can't get to it quick enough. But with an HST or shuttle you would have to keep your foot on the gas pedal or it'll just stop.
/ Skidding Logs with tractor. #24
Our property is not flat, so I was leery of skidding tongs on the 3 point.
I've been using a grapple on front end, and this Small Wood Lot Tools - Timber Maintenance, Pre-commercial Thinning, Firewood, Fuel Reduction skidding tong set up. The skidding tongs are safe because you adjust the lower chain length to drag the log with your draw bar, so the 3 point only lifts the log up off the ground.
I've skidded over 100 logs from 16' to 60' long. Just back up, lower the 3 point and drive off. Rarely have to get off of the tractor to hook or unhook.
Patrick
That thing looks simple enough to make if you can figure out the geometry of the moving pieces...
Dale
/ Skidding Logs with tractor. #25
I think it really depends on what tractor you have...
It's not easy to lift the front of mine, I pull on the top pully on my skidding winch all the time and the front stays down, even with heavy pulls.
SR
/ Skidding Logs with tractor. #26
There should not be a huge amount of pull required to skid a log with the butt elevated, so I have no concerns using the 3-pt hitch for that. If there is a lot of resistance then something is wrong!
/ Skidding Logs with tractor. #27
Or way too much log for too little of a tractor.
Know what you should or shouldn't do.
It doesn't take nothing fancy to drag a log, most important factor is the rump on the seat.
/ Skidding Logs with tractor. #28
I've got an offer to do some TSI with a return of firewood over the next few years,
I'm making plans to drive up north and pick up an Igland 3501 tomorrow. The land is much too "steep" to consider dragging every piece to the landing.
/ Skidding Logs with tractor. #29
I lift with the 3pt receiver hitch..
I pull with a chain under the raised log connected to the draw bar.. That way there is minimal pull on the 3 point..
It is easy enough to take the time to hook up this way..
Many have reported if you ever do raise the tractor front end, you will never let that happen again.. Many seem to have to find out for themselves..
/ Skidding Logs with tractor. #30
FTG-05 Any chance you live close to Maryville Tn? Thanks
/ Skidding Logs with tractor. #31
Have you done much of this before?
I don't do firewood professionally, but I do help out friends with their tree felling and firewood harvesting, and occasionally sell a few cords. I get a chuckle when a friend says, "I have some trees I need to get taken down. If you get them down and process them into firewood, I'll share the firewood 50/50 with you." That's when I explain that a "firewood tree" still standing in the forest is worth $10/cord, maybe $20 if the access is good and you are very lucky (assuming it's not good enough to be used for lumber or veneer). Cut into long lengths and delivered to the customer for them to cut and split, the going rate is around $115/cord. Cut, split and delivered, the price varies, but you can easily get $300+ if it is already well seasoned, ready to burn. So the guy offering to go 50/50 with me if I do all the work is basically offering me $5-$10 per cord to harvest, cut, and split his firewood for him. It can sometimes take a bit to educate people who are offering you this "great deal" by saying you can keep half the wood.
One friend in the auto repair business got the picture when I said, "I'll help you because we're friends. You can do a favor for me or someone else some day. Your offer to share the wood 50/50 is about like me offering you a dozen of my wife's homemade chocolate chip cookies if you'll do this body work on my car. If you really want to come up with something closer to a fair 50/50 split, how about I drop the trees, bring 10-16' logs to your meadow. You cut and split them, and I'll take half?"
/ Skidding Logs with tractor. #32
My long time equipment bashing forest owner friend has this.Small Wood Lot Tools - Timber Maintenance, Pre-commercial Thinning, Firewood, Fuel Reduction He has had it when they first went on the market and absolutely swears by it. He has a stand of 65 -70 year old douglas fir in the coast range of Oregon that he bought in the early seventies. He has thinned it himself. His ground is mostly decent and uses a 50hp Case International 4wd. I've known and worked with him since the seventies. He is prudent with his cash and says you can't beat it for the buck. My comment..... the most dangerous piece of equipment in the woods is a farm tractor.
I remember when he bought the unit. The builder lives not far from us. He went up for a demo and bought it on the spot.
/ Skidding Logs with tractor. #33
I've used a 3pt forklift, chain and the drawbar.
I had the 3pt forklift for moving other things.
I'd get a chain under the log, back the tractor up so the 3 pt arms were on either side of the log lay the chain over the 3pt arms and wrap the chain around so I could easily lift the log, then wrap it so it pulled with the drawbar.
/ Skidding Logs with tractor. #34
I agree John. That's just how people think before they actually try to make money in the woods - Every one of their standing trees is worth a $5000 and it is such a privilege to cut them you don't need to be paid for it.
To me TSI is one of the hardest ways to get firewood. Every tree you cut is surrounded by good quality keeper trees that you can't mark up or damage. Slow and tedious. TSI is definitely worth doing or hiring to have done and can pay for itself down the road. It does produce firewood but that just takes some of the curse off and is seldom close to fair compensation for the work involved. But it also depends on the lot so this is not always the case. Thinning hedge rows can work out OK if you don't have to clean up all the brush. Just pile it.
gg
/ Skidding Logs with tractor. #35
I do enough firewood cutting. Mostly removing dead trees and deadfall. GREAT EXCERCISE.
As far as a paying endeavour, I have little doubt that it's about the worst paying, hardest work you can do. Could it actually even make more sense to process and sell firewood, and buy some other form of energy for yourself, than burn your own wood?
/ Skidding Logs with tractor. #36
Is there any affordable attachment that would make it easy to approach logs, grab them and then drag them to another location?
We had our place logged for pine and there are now a bunch of cedar trees (the loggers cut to get to the pines) that I'd like to harvest and save for future projects.
I'd bet that most are less than 18" in diameter.
I've also thought of building something to attach to the front end loader but wonder if pulling with the loader is OK or something to avoid (kind of like many say you shouldn't use rear attachments to push heavy loads.
I'm figuring I want to drag trees to a common area where I can de-limb them and put the limbs in a burn pile.
Any ideas?
I always used a back blade on the 3 point turn your blade backwards hook your chain to the rear of the blade.mine had factory holes where you adjust the angle of the blade I used one of those holes with a clevis .you dont have to worry about flipping over backwards if the log catches something if your blade is a foot off the ground while skidding your front end will only raise about six inches before the blade will come down and hit the ground and once you get a few pulled out you can shove them out of the way with the blade being turned around backwards. I strongly recommend never skid a log off the draw bar or any kind of implement that wont cone down to contact the ground stopping you from going over backwards because it will happen in a split second you won't be fast enough to push in the clutch to stop it from going over I used this method for thirty years without one having a close call going over backwards
/ Skidding Logs with tractor. #37
Use a back blade turned around backwards you can push the logs where you need them after you pull them out plus it keeps you from flipping over backwards
/ Skidding Logs with tractor. #38
Don’t pull anything “challenging” with the front end loader.
Loader arms aren’t built to do that. Nor are tractors. Tractor’s are built for pulling from the back.
/ Skidding Logs with tractor. #39
John Thanks for the friendly advice.
The other party doesn't burn wood ! ;-) so no 50/50.
And I know how much work it is to haul out fuel wood and work it up. It's much "better" for me to get in a full truck load and just cut and split off the pile.
The way I figure, The winch cost is about 4 loads ;-)
I didn't make it up to do the purchase. Heavy rain on the forecast, and I didn't care to drive in it. The rain came late, it's pouring out there now. Another day. No pulling to do until the snow covers the ground anyway.
There is a cut going on less than a mile from the house. I'll likely buy a load fresh off the forwarder '=)
/ Skidding Logs with tractor. #40
Just thinking out loud after reading the back blade comment.
30 years ago, my Brother-In-Law broke his back from a tractor flip while dragging down a widow maker...old tricycle tractor and was not there, so not sure how he was actually doing it...
If the 3PT hitch is really just providing up lift, (no down pressure) - then can it really stop or prevent a back flip?
Understand the sound logic of always carrying a load low, near the ground...to drop the weight quickly...
But the 3PH does not really act like a wheelie bar on a dragster - there is no real mechanical block from the 3PH preventing a back flip? (That's a question, not a statement).
Not asking this to question the poster or cause conflict, but rather to accurately understand the dynamics on whether a blade on the 3PH will actually stop a back flip.
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
