sizing a bush hog
/ sizing a bush hog #1
southerndeere
Do u guys think a 7' heavy duty bush hog is to much for an 85 hp tractor. 75 pto
/ sizing a bush hog #2
What tractor? What outside rear tire width? With or without FEL counterbalance? How heavy a Bush Hog?
/ sizing a bush hog
Its a t4.85 new holland. It does have a fel. I cznt remember the model on the e mower but it is the heavy duty bush hog brand. An it has 18 tires set on 36 inch row spacing. Not sure of exact outside width
/ sizing a bush hog #5
You could pull / lift an 8' Bush Hog 3008 Dual GB cutter. We have one on a 96 HP NH just to get between trees.
See our Avitar.
/ sizing a bush hog #6
It will, but I'd rather have a dual spindle 8' cutter than a 7' single.
I used to run a 10' cutter with our old 2355, 56 PTO hp.
/ sizing a bush hog #7
I use a 7 foot deck on my LS P7010 and it hardly knows it is back there unless I hit really high wire grass. My deck is made from 1/4" plate all around and weighs more than 1500 pound which makes it a good counter weight for my FEL. A 7 foot is about all I can use to get between the trees where I mow otherwise, I could likely pull a 15 foot batwing but maybe not as fast as I pull the 7 foot. Weeds cut much easier than tall grass so much depends on what you are mowing but with your tractor and a 7 foot mower, you could be mowing down small trees with no problem of power, 5 HP per foot is generally accepted formula for PTO power.
/ sizing a bush hog #8
It will, but I'd rather have a dual spindle 8' cutter than a 7' single. I used to run a 10' cutter with our old 2355, 56 PTO hp.
BH 3008 is a dual spindle?
/ sizing a bush hog
Does multi spindle use less hp?
/ sizing a bush hog #11
a 7ft heavy duty cutter an easily be pulled by an 85hp tractor.we pull a 14ft ridgid brushhogg shredder with a jx80 an 7040 kubota with no probs.
/ sizing a bush hog
Decided to go with a 7 ft gr series rhino. Its supposdly good for up to 4 1/2 inch brush. It will never see that around my farm. But the deal they are giving me I couldn't resist. I can't wait to getthe combo on the farm to see how its gonna run.
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
Informational Lot - Shipping (A63688)
Informational Lot...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
